WTF is this message in TPG? Have received it encoding two movies now! How do I fix it?
Well i have your answer but you will not like it.
You have bad frames. In the parts where it crashs is where they are too. Only way to get rid of them that i know of is by using virtual dub and manually deleting them.
Now another thing-
If you used mIRC and were on the right channels dl mpg files rather than avi or asf files, you would not have that error message appear again.
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one. -
actually just do a direct stream copy using vdub, this usually clears the problem, at least it always has for me. Then make sure you don't have any video dropouts in your clip, therwise when you encode your sound will lose sync.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
