Hello guys
I would like to Capture a 30 mins video.
& have it high quality .
& i wouldlike it to be around 70 or 80 megs..
How is it possible i seen many people Be able to do it
their video looked like vcd & near svcd
how can i make it....
which software i need.
+ do i need to compress it?
what settings i need to put
(im newb in capturin)
thanks guys!!!!!!
So 30 min=80 MB. That means 120 min=240MB!
And you want high quality?
I don't think the quality to achieve that kind of compression would be worth watching. Sorry but I can't offer any solution to get those results. -
i wanna make mpgs to host online
I saw zillions of people make them ....
I have seen ''wrestling match'' with such good quality i could of put it on cd) & it was about 74.6 megs to be exact & contained a 25 + match inside.
Well i dunno how they do it they must be very very good or.... they study in that........ i guess -
If you want bitrates that low you'll want to make KVCD mpeg files:
http://www.kvcd.net -
pfh,
To offer up a simple explanation, ala hayabusa, you want 80Mb (bytes) and it to fit in 30 minutes.
By simple math that would require a video rate (video + audio) of 2.67 Mb/min.
IMHO the lowest video quality would be the VCD standard and yes it can offer a fair degree of quality. But quality is in the eye of the beholder.
The VCD standard is 1150 Kbits/sec + 224 Kbits/sec for audio. That would make for 1374Kbits/sec encoding rate.
Now to convert units 1374 Kbits/sec = 10.305 Mb/min for the lowest quality video recording with MPEG 1 standard.
You are asking for a rate that is about 1/4 of the minimum. Thus, I do not think you will get the quality that you desire.
However, there are some encoding templates that do offer exceptional quality for very low encoding rates such as those mentioned by junkmalle.
Good luck. -
If you want to host your files only the better solution would be to encode to a streamable format such asf wmv9 or real Video 10
HIGH Quality Video
By videohelpnewbie in forum Video Streaming DownloadingReplies: 4Last Post: 13th May 2011, 12:55 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
Recommended Min Quality Video settings for CamStudio
By Firewire60 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 08:11 -
Best way to convert a video to iPod with max quality and min filesize
By Salva Veritate in forum Video ConversionReplies: 1Last Post: 4th Jan 2008, 11:34
