I'm a newbie to this game so hopefully I've got the correct forum. First thanks to all the members whose posts have assisted me to get this far.
My basic problem is that my copy of a home movie on DVD-RW does not copy correctly to DVD-R. Details below
1) I have just recenty purchased a Sony DVD201E camcorder and recordered some footage in Video mode (not VR)
2) Imported this into Intervideo WinDVD Creator, added a title, chapters, deleted some scenes and authored.
3) Burned to a Imation DVD-RW 2X, this plays on PC and DVD player
4) Using Intervideo DVD Copy 2 I copied this to a Imation DVD-R 4X, I'm pretty certain I did this at 2x rate, this works on PC but not a DVD player - this is my problem
5) I've checked the disk quality ratings on this site and they both seem fairly good, actually I went to these disks after some earlier failing with cheaper disks
Any sugestions on where I may have gone wrong. I wrongly assumed that if it works on the DVD-RW, a straight copy to a DVD-R would be OK. Maybe I copied incorrectly, or the software I'm using is not stable. I plan to upgrade my PC but I don't think its low spec is the problem
I do have Nero startsmart/express as well, but haven't used on this occasion.
Thanks in advance for any help
For DVD-5 (any kind) to DVD-5 (any kind) I recommend DVDDecrypter ISO Read -> ISO Write. That wil create a true 1:1 copy. Any differences noticed in playability between original and copy, created this way can only be due to media compatibility issues.
/Mats -
Thanks MatsOriginally Posted by mats.hogberg
Its taken me while geing back to you.
I checked out the DVD Decryptor s/w. It looks good and I will continue to use it. However it didn't quite fix my problem.
I checked out the followng post for using NERO to burn from a TS_Video folder on my hard drive to a disk. I have been successful on DVD-RW and DVD-R disks, works in PC and DVD player.
http://club.cdfreaks.com/showthread.php?s=&threadid=75455
Not sure why it worked, something to do with profile settings, and I think using CAPS when naming the disk/project
I even woke up the wife and told her of my final success - shes estatic!! LOL -
Hm... One thing might be that the VIDEO_TS folder should be upper case only. Now, not all players enforce this, and gracefully understands that video_ts=VIDEO_TS. Some (few, I think) tho, aren't that inclined to bend the standard, and refuses to accept a DVD with a video_ts folder as a Video DVD.
/Mats
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 20:01 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 21:12 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 17:51 -
dvd copy problem
By ht0160 in forum DVD RippingReplies: 10Last Post: 1st Jul 2007, 18:31
