i downloaded an avi file that i want to make into a dvd. i used Nero vision express 2 to convert it to a bunch of VOB files that are: bit rate 5073kb per sec , 720 x 480 CCIR 601 and encoded it with 2 pass VBR. when i watched the result i noticed there are very slight skips happening frequently in the movie and it is 5 secounds shorter then the original AVI file. Does anyone know what is happening?
Could be bad frames in the source AVI, as is very common for "downloaded" AVI files, 'specially those floating around the P2P networks. If that's the case, slight skips is the best to hope for, when converting to video DVD.
/Mats -
How have you verified that the AVI is fine?
OTOH, what happens in oneclickwonder type of applications (like NVE) nobody (besides the creator) knows.
I suggest you try some of the AVI to DVD procedures, that doesn't use this type of applications, described under Convert, left. If nothing else, it's easier to pinpoint the problem, if each step in the process from AVI to Video DVD is made with a specialized app.
/Mats -
please try post in correct forum. avi to dvd is not dvd to svcd/vcd. moving you.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
