Hi, I've been trying to convert my AVI movie files to MPG1(VCD) for the past couple weeks so that I could play them on my DVD player. I've probably downloaded all the conversion programs on the net and have had no luck. They either stop half way or just don't do it. The program i've come closest to with is TMPGenc 2.02, but I am currently having a problem with it. I cannot get it to convert. I can convert the sound to MPG, but when I try to browse and convert the Video it shows my directory path for the file and says "can not open or unsupported." I don't know what to do in order for it to convert the video and audio together. Can someone please help? Thanx
need a little more info to help. are these avi files ones you downloaded, no need for titles please!. Are they in Divx format? With some more info there are alot of help we can offer here.
Yes, I downloaded the AVI files and I believe they are DIVX files because it says "codec: mp43".. I'm glad to see that I can be helped, I have tried really hard but havent been successful.. Thanx
I've had simiar type of problem. One thing that helped me. When your doing the encoding stop the other things that are running on your computer. Anti-virus, internet browers, close all the other things. Just let TMPGenc 2.02 work by itself. The worst thing was Kazaa or lime wire. I was trying you download one movie while encoding another. SOmewhere in the process it would stop. Alway after almost an hour... I haven't had the other problem your talking about. Convert the audio and video together. Besure and load the template for NTSC- VCD.
I've tried closing everything, but still didn't have any luck with my other programs. I really want to convert using TMPgec because it seems to be the best. And yes I do load the VCD settings for it, but it still says that the file type cant be loaded. I think it might be because it might be DIVx but I don't know.
i had the same problem when i first started converting divx'x to mpeg1's...(that was just two weeks ago...just completed my first ever vcd today
anyhoo...i have the exact solution for ur problem...
do this:
-go to OPTION
-then ENVIRONMENTAL SETTINGS
-then click the last tab, VFAPI PLUG-IN
-change the priorities...
here's what they should be:
-direct show... -> 2
-avi vfw... -> 1
-avi2... -> 1
-wave file... -> 1
-bmp/ppm/tga... -> 0
DVD to mpg converting....
By jay_lubb in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2010, 05:31 -
Converting .mpg movies
By baysee in forum MacReplies: 14Last Post: 25th Sep 2009, 06:11 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 06:59 -
Converting .ts to .mpg (HD)
By tomerwiz in forum Video ConversionReplies: 7Last Post: 8th Nov 2007, 14:48 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03
