ok i tried out the software: subtitle workshop but im having probs with the right audio that i want and the aspect ratio..does anyone know how to configure that?
also if you used another subtitle software, which one do you recommend?
Results 1 to 10 of 10
I'd suggest you buy Sony DVD Architect. It's very easy to set some subs with DVDA.
Subtitle Workshop is the best freeware, but you could try Winsubtitler as it is also very useful.
You can not configure audio and video in Subtitle Workshop. -
i tried subtitle workshop..the thing is, the resolution of the movie screwed up, how do i fix that? and what format should i save the files as?
I prefer DVD Architect as I had stated before. I use Subtitle Workshop only for small movies or to correct and save subs, but it definitely is a great choice.
the resolution of the movie screwed up, how do i fix that? and what format should i save the files as? -
i want to make a DVD disk of the movie, the files are VOB, how do i make the person view the film with the subtitles? and what file format should i save them as?
idk how to make a dvd with the subtitles, and how i should extract the subtitles as which file format
Originally Posted by masri
https://www.videohelp.com/forum/viewforum.php?f=44 -
Yeah, you should start reading some guides around here. That's a good start for sure. Then you'll need an application to author and burn your DVD. TMPGEnc DVD Author is quite good and Sony DVD Architect 3.0a is an excellent choice.
Looking for a Subtitle Software with HH:MM:SS:FF mode
By gyzel01 in forum SubtitleReplies: 4Last Post: 2nd Apr 2012, 04:44 -
Software to synchronize a subtitle
By kyrcy in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2011, 11:01 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 12:43 -
Question about inconsistant subtitle timecode with different software
By jimdagys in forum SubtitleReplies: 1Last Post: 2nd Jul 2009, 00:07
