  1. Member Adub's Avatar
    Mar 2005
    california
    Hi all,
    recently I was recording a tv show off abc onto a vhs (I record from vhs to pc) and this huge black box pops up in the middle of screen covering practicaly everyting up except for a few pieces at the edges. Is this some kind of new copy protection used by TV stations now, or what?
    Any help would be greatly appreciated.
  2. the feds are coming.....
    lol
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
  3. Member Adub's Avatar
    Mar 2005
    california
    Thanks, Ill keep that in mind.
    May 2001
    It sounds like a teletext window is popping up. On my TV that is option TEXT4, and since there are no data transmitted in the US, all I see is that black box with tiny parts of the original pic on the edges.
    Maybe you should check your settings...?
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  5. Member Adub's Avatar
    Mar 2005
    california
    Thanks man. What you say makes sense. I was messing with settings like that semi recently. Ill check them and set them right. Thanks again.
