This happened:
My DVD is a LG 4080 Slim for notebook. But I using it in a case external.
The media is Memorex DVD+R .. Also I used SKY DVD-R but din't recognize by the burner.
1) I made my DVD on Pinnacle 9 and when I burned, the software say that burned but when I open the dvd has nothing burned. Looking the back of the DVD sounds that something burned, because change the colors of the lines. But just a little line like 2 mm.
2) I try Ulead Movie Factory 3 And I just get really burned with Ulead Movie Factory 3. But just a data burned. A small file. And All dvds that burned and did't work has the same size of the lines on the back. And the dvd that really burned was bigger the line on the back of DVD.
But when I burn a DVD project it start to burn and a ERROR happened. Say the it "Failed".
3) I used nero and occured a Error and I burned. I the lines on the back of DVD has the same size that all DVD that occuried errors when burned.
I don't know what this can be, Please helpppppp
it is a virus, incompatible Media, hardware problem, dvd burner problem or whatttt ???????????
Thank You for everyone...
I think it is a dvd burner problem. If possible try to change...
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Are you sure you didn't have your burning software write to an image file rather than to disc?
Video is Crazy!!! Very strange problem with FourCC!!
By Cauptain in forum Newbie / General discussionsReplies: 7Last Post: 22nd Nov 2011, 17:32 -
Weird Problem with Handbrake
By LegendaryLero in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2011, 01:20 -
Weird HDMI problem
By WinSpecToR in forum ComputerReplies: 6Last Post: 29th Sep 2010, 05:22 -
weird sd card problem
By fromunda kid in forum Newbie / General discussionsReplies: 8Last Post: 16th Feb 2010, 13:52 -
weird computer problem
By deadrats in forum ComputerReplies: 23Last Post: 24th Jul 2009, 20:10
