Hi
I have Svcd made from dvd it plays fine on my pc but when it is played on my dvdplayer sony dvp ns305 the sound sounds heavy. the bitrate of the audio in svcd is 224. why would this be happening.
Reduce the BASS level of your TV set or amp.
But seriously, unless you tell the exact process of creating your SVCD from DVD it is difficult to analyze. Did you encode the audio separately or what ?? -
Well you could try this manual procedure. Though DVD2SVCD also does something similar.
If you have the original DVD rip it to hd using DVDDecrypter. Make sure file splitting is set to "No Split" so that you get one big VOB file. Use TMPGEnc. Select MPEG Options > Simple Demultiplex. Open the VOB and split into audio & video streams. Convert the audio (probably AC3) to MP2 224Kbps bitrate at 44.1Khz. Use HeadAC3he for this.
Now convert only the video with TMPGEnc to SVCD compliant M2V file. You have to select the video stream as MPEG-2 under advanced tab.
Once you have both the M2V file & MP2 file then select the MPEG Options > Simple Multiplex option in TMPGEnc to mux the two streams into a MPEG file.
Play the file and see if there is any difference.When I was born I was so shocked that I could'nt speak for 18 months.
Need heavy duty LightScribe burner
By Robert W Cleary in forum MediaReplies: 5Last Post: 25th Apr 2012, 17:33 -
The Thing 2011 prequel **Heavy spoilers!!**
By retroborg in forum Off topicReplies: 6Last Post: 27th Mar 2012, 09:03 -
Heavy pixelation when fast forwarding h262 video (megui)
By VistaXP in forum Video ConversionReplies: 6Last Post: 22nd Jun 2010, 01:44 -
1080p movies are to heavy for my PC?
By fussgen in forum Newbie / General discussionsReplies: 17Last Post: 30th Aug 2009, 22:20 -
how to remove heavy noise in video?
By Driftking978 in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2008, 04:24
