Hello all. Is there any software outhere that can burn DVD disk to disk instead of many softwares ripping the dvd to the hard drive and then burning it?
Maybe im dreaming but is this possible?
Um, Nero. I'm sure there are others as well. Of course this is for a Single layer, non-protected disc, such as a burned disc.
If the source DVD is copy protected, such as virtually all commercial DVDs, then you do need some type of ripping software. AnyDVD will work as waheed mentioned, but I think most people will rip the DVD first, then shrink to fit on a DVD-R. This is mostly for cost savings. DVD+R DL discs are still $6-$7 a piece where DVD-R discs are under $0.50 a piece. AnyDVD has a free trial of 21 days after which you must registerand pay $39. DVD Decrypter does not work in the background, but does work quite well and is free.
If your source DVD is not copy protected and is under 4.5gig, then Nero will work well.
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 13th Feb 2011, 23:05 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 18:15 -
Burning HD 720p to dvd disk.
By compduce in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 01:12
