  1. I have been cleaning out my hdd and found some old movies that i have not Burned yet.
    cant remember which program i created them with anyway the 2 folders are one the normal VIDEO_TS and one a VIDEO_RM
    Do i need to burn both these or will it work if i just burn the VIDEO_TS..
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    You can discard the VIDEO_RM folder, as this is for extras on the dvd that runs with Interactual Player on a PC ONLY if I remember correctly.
    You only need the VIDEO_TS.
