in the DVD BACKUP section, under DVD RIPPING SPEED TIPS i did step #3 uninstalling primary controller now my windows does not start normally....i have to keep running under last good known configuration....and when it does go through, the hardware wizard keeps detecting new hardware ide channel, primary ide controller and then it asks me to reboot again...and when i do, same thing happens again..wizard detects ide controller again, installs it and asks to reboot again....windows still does not start normally....it was suggested to try updating chipset drivers and did that..still same prob.....any help??? sorry if topic in wrong section, not sure where to post.........
I think the computer forum is the right place for this.
Thanks Mike -
Do you mean you uninstalled the Primary Channel? You don't need to uninstall the controller itself, just the channel. Have you tried to roll back the driver? Or do a system restore?
Also try booting in safe mode, you may be able to access the system restore or the Device Manager if you aren't able to in regular mode.
If you have the OS disc, you should also be able to repair it from that. -
looks like it is the primary channel.....tried rollin back driver, but it says that there is no backed up driver....for some reason i am not able to boot in safe mode...everytime i try it just loops back to the same screen and only way i can boot is through last good known configuration..i can access device mgr in regular mode....i dont have a windows cd just a recovery cd that came with my computer....so you think i will just have to do a complete system restore as in reformat my hd??.....or is it something else you mean by system restore...i just dont understand why windows installs the primary channel and gets the software for it but then when it tells me to reboot, its as if nothing happend and it detects again and again i have to reboot....thanks for the help and sorry for the noob questions.....
XP has a system restore in the accesories folder, available in the start menu. If a restore point has been lately set, you may be able to return to the point before you encountered the problem. Doesn't always work when the OS has major changes to the registry.
Other than that, it depends a litttle on the setup of your OS. OEM versions of XP may not be exactly the same as the retail versions. If all else fails and you can back up your files, reinstallation of the OS is one option.
The restore discs may also do a OS restore or repair without damaging your files, but I would never depend on that.
I have unistalled the primary channel on a couple of systems, and it just reinstalls it with no problem. Maybe your OS version is slightly different. -
hey thanks again for the reply....it looks like everything worked fine once i uninstalled Daemon tools and Alcohol 120%....might have been causin some kinda conflict or something.....i was about to back everything up and just do complete restore, but another buddy suggested deleting those programs...now boots up fine and i actually see the primary ide channel in the device mgr.....so looks like everything is ok now....thanks again for your help.......
Hey, glad you got it fixed.
Did your buddy have any idea why those programs might have caused the conflict? Might be good to know for the future.
It's most likely the virtual drives were tied to the IDE channel for some reason and caused glitches with the reinstallation. I've never seen it happen myself but I don't usually leave the virtual drives on either.
What do you use as your primary computer monitor?
By johns0 in forum PollsReplies: 10Last Post: 17th Feb 2010, 22:07 -
Uninstall Office97 Problem
By bevills1 in forum ComputerReplies: 6Last Post: 26th Jun 2009, 15:39 -
Quicktime wont uninstall/install
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2009, 13:44 -
pci ide controller problem
By makemepure in forum ComputerReplies: 4Last Post: 29th Apr 2008, 21:20 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
