i want to convert .mpv to .avi in VirtualDubMod , but im a noobie , and whenever i try to convert it , the file is really massive , like over 9gb! i read the projected file size on the statistics and it says "12796.90mb" . somebody help me shrink the file size!
Next time check on the left where it says HOW TO CONVERT,i found this link within a minute.
https://www.videohelp.com/avi2divx.htmI think,therefore i am a hamster. -
er..thnx and all . but i need subtitles in them , and that guide kinda disables it
Would have helped if you gave more details,also the search is good way to find links to the question you just asked.Input "avi with subtitles" and you will get some tips.
Video -> Compression... then select an appropriate compression codec like DIvx of Xvid and set the parameters you want.
hm..i keep getting errors from my Virtualdub , it keeps saying "No video frames found in MPEG file" whenever i try to open the file. its weird cos the video does work
You are using VirtualDubMPEG2 or VirtualDubMod right? The regular VirtualDub cannot read MPEG files.
thnx , er..whenever i try to open the file virtualdub crashes . it never used to happen before when i try to open it with virtualdub !!
Could someone help me through converting vob to avi using virtualdubmod
By alex.ap.pacman in forum Newbie / General discussionsReplies: 11Last Post: 14th Feb 2011, 19:38 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
Extract Subtitle embled in AVI file,VirtualDubMod n GraphEdit didn't work..
By quang010692 in forum SubtitleReplies: 1Last Post: 5th Oct 2008, 02:44 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
