There was a power failure while I was doing a recording with Virtual VCR. As such, the avi file left in the harddisk cannot be read and decode by my player.
does any know if there is any way to recover this file? Thanks!
Leon
VVCRS, Scheduler for Virtual VCR. Now also for VirtualDub (beta)
If you can see the file on the drive, try running it through Virtualdub. It can sometimes restore a partial file.
Originally Posted by redwudz
VirtualDub says that it is not a valid avi file. I tried to us AVIRepair frin http://www.pk3.org/Astro/index.htm?software_utils.htm and now Virtual reports missing MOVI block.VVCRS, Scheduler for Virtual VCR. Now also for VirtualDub (beta) -
Originally Posted by Soopafresh
I tried AVIMaster and it returns "Unexpected Token". I then use AVIRepair to fix the avi header and I getCode:AVIMaster 1.2.1 (c)2004-2005 by thozie productions, Thomas Ziegler, München Contact and Bug Reports: www.thozie.de/avimaster, avimaster@thozie.de D:\Videos\Test2.avi Reading 'Test2.avi' (1516604928) 'RIFF' (5770232) 'AVI ': RIFF AVI Chunk, Segment #1 'LIST' (65084) 'hdrl': AVI Header List 'avih' (56): AVI Main Header 00 microsec/Frame: 40000 04 Max Bytes/sec: 262283 08 Padding Granularity: 512 12 Flags: 0x00000800 + TrustCKType 16 Total Frames: 575 20 Initial Frames: 0 24 Streams: 2 28 Suggested Buffer Size: 16189 32 Height: 288 36 Width: 352 -> Length: 0:00:23:00 (25.00 fps, PAL) -> Video Frame Size: CIF, PAL-VCD, -DVD 11:9 'LIST' (32372) 'strl': AVI Stream List #1 'strh' (56): AVI StreamHeader 00 Type: 'vids' 04 Handler: 0x44495658 'XVID' 08 Flags: 0x00000000 12 Priority: 0 14 Language: 0 16 InitalFrames: 0 20 Scale: 400000 24 Rate: 10000000 28 Start: 2 32 Length: 574 44 SampleSize: 0 (Variable) 48 Frame (l t r b): 0 0 0 0 *** Warning: AVIMainHeader Width: 352! *** Warning: AVIMainHeader Height: 288! -> Length: 0:00:22:24 (25.00 fps, PAL) 'strf' (40): AVI StreamFormat 00 Size: 40 04 Width: 352 08 Height: 288 12 Planes: 1 14 BitCount: 16 16 Compression: 0x44495658 'XVID' 20 SizeImage: 608256 24 XPelsPerMeter: 0 28 YPelsPerMeter: 0 32 ColorsUsed: 0 36 ColorsImportant: 0 'indx' (32248): AVI Stream Index 00 LongsPerEntry: 4 02 IndexSubType: 0 Default Frames 03 IndexType: 0 IndexOfIndexes 04 EntriesInUse: 1 08 ChunkId: '00db' 'indx' Entry #1 16 00 Offset: 65536 08 Size: 32256 *** Warning: Non-standard Chunk-Index size! 12 Duration: 574 (0) *** Warning: Unexpected Token! [deleted] (0) *** Warning: Unexpected Token! "............................................00db.>..." (0) *** Warning: Unexpected Token! "....................................00db.>..........." (0) *** Warning: Unexpected Token! "............................00db.>..................." (0) *** Warning: Unexpected Token! "....................00db.>........................g.," (0) *** Warning: Unexpected Token! "............00db.>........................g.,..Rc...." (0) *** Warning: Unexpected Token! "....00db.>........................g.,..Rc....XviD0036" *** Error: Chunk size greater File size, File may be truncated! *** Error: Token Size greater Chunk Size! (1650733104) *** Warning: Unexpected Token! *** Error: File ends prematurely! ".>........................g.,..Rc....XviD0036.....`o." *** Error: Missing 'movi'-Chunk! Statistics ----- AVIStreamHeader #0 'vids' *** Error: 'indx'-Entries detected, but no 'ix##'-Entries! *** Error: 'indx'-Entries detected, but ODML-Header not found! *** Info: Chunks detected, 'Idx1'-Index (KeyFrames) and ODML-Index Entries *** 'indx': 1 (DF: 0), 'Idx1': 0 (Key: 0), ODML: 0 *** Error: Video Frames detected: 0 AVIMainHeader Frames: 575! *** Error: Video Frames detected: 0 AVIStreamHeader Length: 574! *** Warning: Max Frame Size detected: 0 SuggestedBufferSize: 16189! *** Warning: No 'auds'-Stream detected! Writing 't.avi' 'RIFF' (16864) 'AVI ': AVI Main Header Phase 1 'LIST' (4) 'movi': (Segment #1) 'RIFF' (16864) 'AVI ': AVI Main Header Phase 2 'RIFF' (16868) 'AVI ': Segment #1 'LIST' (16844) 'hdrl': Segment #1 'LIST' (16500) 'strl': Segment #1 'vids': Stream #0 'indx' (32760): MetaIndex #1 00 LongsPerEntry: 4 02 IndexSubType: 0 Default Frames 03 IndexType: 0 IndexOfIndexes 04 EntriesInUse: 0 08 ChunkId: '00dx' Total Files processed: 1, Total Size: 1516604928 (1446MB), Elapsed Time [s]: 3.58
Any other suggestions?VVCRS, Scheduler for Virtual VCR. Now also for VirtualDub (beta)
Video Converter Crashed during last 50 seconds....how to fix a mp4 file?
By borgqueenx in forum Video ConversionReplies: 4Last Post: 19th Feb 2011, 15:54 -
UBuntu, workpane crashed, mouse active ... keyboard recover?
By edDV in forum LinuxReplies: 3Last Post: 22nd Oct 2010, 03:22 -
VirtualDubMod crashed on me while opening an MKV file
By The Monarch in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2009, 06:57 -
Recover a program file
By BLSAMPLES in forum ComputerReplies: 5Last Post: 28th Jul 2009, 23:17 -
Restoring information from crashed video file
By kocu in forum ComputerReplies: 5Last Post: 11th Dec 2008, 13:52
