  1. hello all for when i get my next pc i want it to be very flashy with neon lights and i seem to like this clear blue neon glowing case to go with blue led's and whatnot. http://shop.store.yahoo.com/directron/cs888cl.html Anyone else here use a clear case?
  2. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Mine has a window, but the entire case isn't clear. Then again, mine is fairly out of sight so it doesn't matter much. If you're thinking about an acrylic case, I hope you're not a smoker.
    Nothing can stop me now, 'cause I don't care anymore.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Mine also has a window. I dont think you'll find many people here that use an entire clear case.
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    I saw a well-done clear case at a large LAN event once, but you have to keep dusting them and cleaning them because the acrylic clouds up pretty easy. And yeah, smoking around the thing is right out.
    Now if you were to have one custom built from plexiglass or lexan then you'd have a near-bulletproof, stain-proof PC case. It'll cost you some serious cash though, the last display case I had done for a model ship was just a simple 5-sided rectangular case of poly and it cost me over $100. Having one built with ATX case specs would probably run around $500-800.
    FB-DIMM are the real cause of global warming
  5. Member Soopafresh's Avatar
    Jan 2004
    I just don't find the insides of a PC to be all that pretty. Now clear bikinis, I'm all for that
    Jan 2003
    Nassau, Bahamas
    those type cases are hard to clean, and to scrape easily man...you should one with a window in stead
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
