I brought six mono files (3 front, 2 rear, one LFE) into Audition and designated each one to a specific channel. I burned the 1-min file to DVD with a black video running. However, upon playback:
- No sound came from the right surround speaker
- No sound cam from the right front speaker
- The subwoofer seemed to be playing one of the other tracks, and not the LFE track
I know bass from other channels sometimes bleeds into the sub, so that doesnt bother me. But why is it that two of the channels didnt play any sound? Is this because DVDs can only handle 4 channel PCM tracks or something?
Id appreciate anyone's help, and thanks in advance.
Results 1 to 9 of 9
Well it certainly came out of more than two speakers, lol. I do currently use AC3 but Im wanting to experiment with PCM.
You have to turn my DPLII on manually, so no it wasnt that. It was surround sound, albeit with a few errors
Some checking shows that you can, theoretically, have up to 8 channels in an LPCM stream, however I have never seen any disks using more than 2 because of the outrageous amount of space required to do more. Which leaves me to wonder if your amp is able to correctly present multi-channel LPCM output, or if Premiere is able to correctly encode it ?
Read my blog here.
Its Adobe Audition Im encoding it in. Where did you read about having 8 channels, BTW?
Check this definition
http://www.afterdawn.com/glossary/terms/linear_pcm.cfmWhen I was born I was so shocked that I could'nt speak for 18 months.
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 14:24 -
Why did my DTS track get converted to 2 ch. PCM ?????? Please HELP :(
By Spdngblt56 in forum AudioReplies: 2Last Post: 12th May 2010, 02:17 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 21:07 -
Extracting The PCM Track from a DVD
By FBI Agent in forum AudioReplies: 2Last Post: 29th Oct 2007, 02:42
