well I've been makin SVCDs w/ TMPGEnc for the last 20 days... overall it hasnet been too bad... but my 30 Trial is running out... I was wondering (cuz i'm kinda too lazy to actually find out for myself) if once the trial runs out if i can just re-install it or if i have to find a crack or something. I would buy the damm thing but you can't. Also i was wondering how much difference there is between an VCD and an SVCD. Is the difference really that big? Cuz I've made some pretty nice VCD which (i think) are comparable to SVCDs. Thanks
BTW - This is not a crack, hence the reason I can post it for you...
Now you can use the wonderful software TMPGEnc without MPEG-2 function 30
days restrictions.
Please be careful when editing the Windows registry - a damaged registry
means that Windows will not boot.
Do the following:
1- Start the Regedit.exe program on the windows folder.
2- Execute Regedit.exe.
3- Erase the key:
My computer\HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
Now, try to open TMPGEnc and just click on Help/About.
It will appear this message: "You can use MPEG-2 funcion as trial for more
30 days"
Don't forget to repeat these procedures to each 29 days.
Great tip
:P . My 30 days are almost up 2 days left. I tried regedit.exe and it works I have 30 days left again
Your tip was too good to belive. belive it or not it works. thanks for the input. 8)
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 08:32 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 09:25 -
Thoughts on Tmpgenc Express 3.1.5.82 Trial
By Batfink in forum Video ConversionReplies: 15Last Post: 30th Oct 2007, 01:17 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 17:25
