I'm trying to update the above, but the download is a .bin file, but no .cue. Anybody any ideas? To add to the problem, the manual says you need to unzip it first......
ARS-2022D
Version:2.06Z
Burn into the CD and then update from CD/DVD-ROM
Modify to support:
ASUS DRW-1608P
PIONEER DVR-109/A09
i think i burned the bin as an iso onto the dvd, i've only done this once a while ago.
this is what my manual says:
You can get the newest firmware version from ACARD by e-mail,or download it directly from the website http://www.acard.com then, unzip the file "cdxxx.bin" and copy it into a blank DVD.this is from a model ars2021d hope this helps -
Thanks for that, but the file is 'unzipable' as far as I can tell......
I've always assumed a bin file needs a cuesheet to burn, and that it's different than an ISO.
Is there a way of verifying this is a non-corrupt file, constructing a cue sheet or anything else to get it to burn?
Cheers. -
I too am having the same problem
getting F/W NOT MATCH Message
how did you get yours to work ??
Firmware update after regionhack?!
By little demon in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Nov 2009, 23:50 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46 -
Firmware Update Question ##
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2008, 06:56
