whats does the media edition have it in thats so special???? and if i want to use streaming to other computers on my network or across the net is it a good investment????
Results 1 to 19 of 19
you have to buy a PC to get the media edition
you can't just buy XP Media Edition and install it"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Originally Posted by Xylob the DestroyerNothing can stop me now, 'cause I don't care anymore.
groovy
The whole point of OEM editions is that Microsoft won't support it unless it's installed in its original PC. Don't go calling their support number unless you're willing to suffer some abuse. Only manufacturers are supposed to buy OEM editions. Buying a Microsoft product without customer support is fruitless - who of us has never had to call Microsoft support over some issue?
*raises hand*
Nothing can stop me now, 'cause I don't care anymore. -
i hve MCE on my computer- seems to do a good job but haven't been able to compare xp pro with it. i don't think you would be dissapointed with either version
the last time I had to call M$ for support, it only took about 2 minutes to get to a real person and they were incredibly helpful
i was amazed"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Originally Posted by shelbyGT
Google searches of problems tend to yield better results than a call to MS. The last time I called them was to get another copy of my XP Pro CD sent to me after losing mine and that was over a year ago. I don't contact them for technical support. I have a pretty good base of internet forums to get answers from for that.
As for MCE vs other versions of XP:
MCE seems to me the best value. Not only do you get most of the functionality of XP Pro it also has the MCE app built-in. In addition to what ViRaL1 stated it also has IIS and SMP support like XP Pro. With a price generally between that and Home I'd recommend it.
You won't be able to stream video on your home network with MCE though. You'll have to set up a server for that of some sort. The Media Center app itself is meant mostly for dedicated home theater use. When you're not using the MCE app then the computer functions just like XP Pro. Unless you set up an SMP system in which case you can use both the Media Center application while using the Windows OS itselfFB-DIMM are the real cause of global warming -
MCE has some very nice features. Although I have had it fail a couple of times to start recording, but I think I have fixed the problem because it hasn't failled in months.
This plan is so bad, it must be one of ours. -
I've never called 'em either. I've found more help thru tech forums like this one only for computer related- + I learn more.
Back to the question- guess it depends on how you use your machine doesn't it? MMC might be more proprietary in nature I would guess. Gonna check those links above............ -
MCE sucks.
Check it's recording format, and the difficulties people have with burning.Cheers, Jim
My DVDLab Guides -
Recording format is MPEG2 in whatever flavor your hardware encoder outputs. Get a crappy encoder you get crappy video, sounds right to me. The only thing MCE adds is the header to make it proprietary but it also encodes the subs with it as well as program information. There are freeware apps out there that strip the header and leave only the MPEG-2 elementary streams. Burning support does suck, but it's meant mostly the author the proprietary MPEG streams for playback in MCE systems only. If you're burning the proprietary format right out of Media Center then you probably shouldn't be complaining about how it doesn't work in your friend's computer or DVD player because you don't know what you're doing to begin with. Just speaking about some MCE users in general on that last part.
1080 hd in a regular dvd
By luc13137 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 1st Mar 2010, 12:31 -
Anyone using Windows XP Media Center Edition? Thanks for help.
By seymoria in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2008, 22:27 -
Windows Media Center can't burn its own files? (Vista Premium edition)
By yoda313 in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Apr 2008, 15:44 -
xp black edition
By zookeeper525 in forum ComputerReplies: 5Last Post: 4th Jan 2008, 22:26 -
A patch for Windows Media Centre Edition to accept any capture card?
By mikee55 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2007, 10:52
