I'm having problem with DVD Skrink 3.2, it keep giving me a error after the backup is done saving to the hard drive and right when i put a blank dvd in, it burn for a couple of second then it give me a error..i wasted some many blank dvd on this problem.. anyone know what's wrong. i reformat my pc and it still giving me the same problem. i try dvd decrypter too and it's giving me a problem too when i burn it. On nero it let me burn cd r but it won't let me burn Dvd.. this is what it say on Dvd skrink when it give me a error
1A23-8035-1254-7171-5077-8348
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero API version: 6.6.0.8
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <HP DVD Writer 400c> Version: Bh04 - HA 0 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 0
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : HP DVD Writer 400c atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6E040L0 atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
HP DVD Writer 400c D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047024kB)
Free physical memory: 631MB (647040kB)
Memory in use : 38 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.4.2005
NeroAPI
12:18:33 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
12:18:34 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
12:18:34 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
12:18:34 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
12:18:34 PM #5 Text 0 File Writer.cpp, Line 122
Writer HP DVD Writer 400c running
12:18:34 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
12:18:34 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
12:18:34 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3293
12:18:34 PM #9 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
12:19:00 PM #10 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286543 (508:07.18, 4465MB)
12:19:00 PM #11 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO
12:19:00 PM #12 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: HP DVD Writer 400c, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: E01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 0
12:19:00 PM #13 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW.)
12:19:00 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286544 (2286544) = #2286544/508:7.19
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286544 blocks [HP DVD Writer 400c]
12:19:00 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HP DVD Writer 400c] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682842112, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286544 | lead-out | 1 | 0x41 | 0x00
12:19:00 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
12:19:00 PM #17 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
12:19:00 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
12:19:00 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 8x (11,080 KB/s)
12:19:00 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:19:00 PM #21 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 0 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: E01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 00 43 4D 43 20 4D - 41 47 00 45 30 31 00 38 ...CMC.MAG.E01.8
23 54 37 10 02 38 6A 02 - 88 67 15 15 0B 0B 08 08 #T7..8j..g......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
12:19:00 PM #22 Text 0 File DVDPlusRW.cpp, Line 638
Start write address at LBA 0
DVD high compatibility mode: Yes
12:19:30 PM #23 SCSI -1106 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x00C70000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x73 0x03
12:19:30 PM #24 CDR -1106 File Writer.cpp, Line 311
Power calibration error
12:19:30 PM #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:19:30 PM #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:19:30 PM #27 SCSI -1176 File Cdrdrv.cpp, Line 1181
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x72 0x03
12:19:30 PM #28 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
12:19:30 PM #29 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
12:19:30 PM #30 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 8x (11,080 KB/s)
12:19:30 PM #31 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
12:19:30 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Try newer firmware. Your writer has some available here:
http://www.firmware.fr.st/If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
"12:19:30 PM #24 CDR -1106 File Writer.cpp, Line 311
Power calibration error "
Usually bad media. Try different media first. Then maybe the firmware upgrade Shocker Milwaukee suggested.
Can also be caused by a dirty laser lens.
Jerked images upon buring DVD
By Ilovm in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 11:28 -
Help a newbie out buring AVCHD.
By flyin-lowe in forum Newbie / General discussionsReplies: 5Last Post: 3rd Nov 2010, 12:47 -
Would really love help with buring videos to Dvds.
By Freakypenguin447 in forum Newbie / General discussionsReplies: 10Last Post: 9th Oct 2010, 21:16 -
MS Movie Maker and buring DVD
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 17:49 -
Buring video to DVD player
By BVG in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2009, 14:58
