Yep,same one i linked to 2 posts up.Originally Posted by Shocker Milwaukee![]()
Tom
Results 31 to 43 of 43
Trust me, your firmware doesn't want to meet my firmware in a dark alley.Originally Posted by jtommyjIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Umm serious, that is the same one. LD=Liggy & Dees, 3520, 1UC is the latest.Originally Posted by Shocker Milwaukee
So basically, if your firmware meet his firmware in a dark alley his would win because his got the first punch in.
Ok so I have it as master,
DMA is ON. Firmware flashed with:
http://www.micheldeboer.nl/firmware/3520/LD3520_1UC.zip
i got the read speed up from 1.6X to like 5-8X Tops.
Any other firmware, or suggestions?
http://www.micheldeboer.nl/firmware/3520/LD3520_1UC.zip -
5x-8x on what size disc ? That is normal for most burners on a DL disc. Try one that you have burned and then report that speed. Burners will only rip at ~16x on a single layer disc.
Tom
im using regular 16X disc. My problem isnt WRITING, my problem is READING!
only 5-8x read speed of regular DVDS from like blockbuster
That is why both myself and lenti_75 specifically say "rip" in our replies to you. That is the process of reading,or "Ripping", a DVD,not writing. You may need to read up on this to get a better grasp of the terms used.Originally Posted by BGALLTHAT
Reading at 5x to 8x on a disc bought at Blockbuster is normal IF IT IS A DUAL LAYER DISC. It is NOT normal if it si a single layer disc and Blockbuster sells both,hence why i asked you if it was a single layer or dual layer disc which you still didn't answere but i'm guessing is dual layer.
Originally Posted by jtommyjSo everything is normal so good luck.Originally Posted by lenti_75
Tom
tom how do i check if it is a dual layer disc?
by the size? its its more then 4.7GB then its dual layer? or what. sorry that im bad at this -
Yeah,look in your my computer and see what size it says the disc in your burner is that you are trying to rip, like 6.7GB's or 3.8 GB's,etc.
Tom
yea they are mostly Dual Layer.
Thats why it takes so slow.
Tom one more Quetion.
I used dvd decryptor for a movie, and i have a file thats like 8GB now. How the hell am i supposed to put it on a DVD. do i need two dvds or what, i do have a dual layer burner....
and if ur wonderin the only reason i used dvd decryptor because for some reason CloneDVD gave me some error.
Thanks -
You have some options
1) Shrink the DVD (Many many guides on the left with free tools)
2) Split the DVD (again,many guides on the left)
3) Rip it to your HD in ISO format from DVD DEcrypter (Mode>ISO>Read) then buy some Verbatim DL discs and burn it with DVD DEcrypter(Mode>ISO>Write)
Those are your 3 options you have.
Good luck.
Tom
Which Media player reads timecode?
By sp_key in forum Software PlayingReplies: 7Last Post: 20th Dec 2012, 16:22 -
Blu-Ray player that reads MP3's
By Megaman00001 in forum AudioReplies: 1Last Post: 21st Nov 2010, 07:55 -
Image Grabber reads all file extentions except wmv...Why?
By King_Tut in forum Capturing and VCRReplies: 9Last Post: 20th May 2009, 16:00 -
Question about OCR that reads Chinese
By jimdagys in forum ComputerReplies: 1Last Post: 27th Nov 2008, 08:57 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40
