Hi,
I recently purchased a RJ-HD by Rjtech (a portable DivX Player) but I am having a few problems with it. It works just fine when I plug it into the computer, it takes in the information and the files but when I plug it into the TV it shows the menu but it doesn't show any language... just blocks and beside that a number 0... (probably meaning it doesn't detect the files). Now I don't know how to fix this, but there is a firmware available to update this RJ-HD but I am not sure if it will fix it... because if I install the firmware onto the HD than I cannot even return to where it was purchased. Any help on how I can get it working? It just doesn't show the ROOT MENU and it has no language lol. I contacted technical support when it didn't work at all but now it works with the computer and I don't want/cant contact tech support due to it being saturday. Plz someone help
Regards,
diE
Results 1 to 1 of 1
LiVe iS juSt EvIl SpElLed BAcKwArDS!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
