Does any of you would know a good dvd Authoring Software, a one that works with subtitles, motion menus and resume links, as the dvd-lab pro, because the dvd-lab pro has some bugs.See an example bellow:
The dvd-lab pro render motion tool have I only seen in dvd-lab pro...it is not actually any dvd authoring..more video editing.
Some tools with motion menu and subtitle support:
ulead dvd workshop
dvd architect
Sonic ReelDVD
Adobe Encore DVD -
But I think that render films with The premiere , p.e., isn't easy as with the dvd-lab pro.Originally Posted by Baldrick
Yeah, old ReelDVD. It gets no love here at all. Matter of fact, I think I'm the only one here using it. It will do subtitles and motion menus but I'm not sure what you mean by resume links. It doesn't do much other than author DVDs though (much like DVD Lab). It allows for a lot of flexiblility with menus. And you don't need photoshop, I've been using GIMP (free) with no problems at all.Originally Posted by Baldrick
For still menus I use Photoshop 7, and for motion menus either Vegas 5 or After Effects 6.5, with phtotoshop for the overlays (subpictures). At present I am trailling Autodesk's Combustion 4, as I prefer node based compositors to AE's timeline, although AE's tools are great.
This is how the pros work. Prep all your assets in advance, based on a menu deisgn and bit budget.Read my blog here.
Ok, thanks a lot. I will try to use all of those, but always keeping to find softs which, if can't also do all of these, at least may do a lot of things, then I may use a less number of softwares.Originally Posted by guns1inger
Need good BD Authoring software
By faramith in forum Authoring (Blu-ray)Replies: 7Last Post: 13th Sep 2010, 22:17 -
Which authoring software has good motion wedding menus?
By sterankin in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2010, 05:21 -
A good dvd authoring program?
By t_jay17 in forum Authoring (DVD)Replies: 3Last Post: 31st Mar 2010, 22:50 -
Looking for a good authoring software that support using MP4 files to DVD
By LegendaryGamer in forum Authoring (DVD)Replies: 4Last Post: 10th Mar 2010, 17:04 -
What's a good dvd authoring program to use?
By zanos in forum Authoring (DVD)Replies: 14Last Post: 3rd Mar 2008, 12:11
