  1. I found a bunch of computer games on a newsgroup and when I got them they we're broke up into a .rar format. When I put them together and unzipped them, they we're bin and cue files. Do anyone know what do I do with these to play them on my computer?
  2. you have to burn them on a CD....try FireBurner, CDRDAO, or CDRWin to burn them on a CDR
    Sep 2001
    Canada
    Yeah, CDRWin is the best for doing that.
  4. I'm cheap. They want 60 bucks for CDRWIN. can anyone help me out.
  5. Get VCDEasy, turn on the advanced settings, go to tools and CDRDAO tools, burn the image file from there... or get a job
    Mar 2001
    Canada
    Well, if you have a bit of patience, CDRWin will burn at 1x without registration, at least it did last time I checked.
  7. ************************************************** **********
    Select CD image :
    You can type directly the name of an image file in the edit zone, or click to browse CD image files across your computer.
    You can also drag-drop an image file from the explorer to this window.
    Blindwrite accept CD image of 4 formats :
    Image format main file extension CD image generated by
    Blindwrite .BWT (up to 3 files - .BWT, .BWI, .BWS ) Blindread > 3.0.0.23
    CDRWIN .CUE (2 files - .CUE and .BIN) Blindread any version
    Goldenhawk CDRWIN
    IGD's FireBurner
    MightyWriter .WAV (1 file - .WAV) Poikosoft MIGHTYDAC
    Iso 9660 .ISO (1 file - .ISO) Lots of CD software can do
    From Help File on BlindRead / BlindWrite Suite vr.0.99.1.3
    Blind read/write supports every famous Image-File format.
    I never had any trouble burning any CD with the protection on it(not relavent to the topic)
    Dig it up at http://www.blindread.com they have a free 30 day trial ver.(Aahmm...crack.....yea)
  8. CDRDAO is free, it's also the best. However, it's a DOS/command line program so you'll want a GUI to run it. VCDEasy is a good choice or XDuplicator. You can find them at http://www.doo9.org Do a google search on XDuplicator.
