Do you know, how i can convert sub file with *.idx to *.srt file ?
I cant use subworkshop to do it , and some program around here to do it , too![]()
Results 1 to 9 of 9
use the search, search for idx and sub:
https://www.videohelp.com/forum/viewtopic.php?t=265491 -
Thanks guys
Subrip is working good, but after i save matrix file for future sub, then i open another sub with the saved matrix file . Then subrip force me to reconize character matrix again ?! Of course i opened the matrix file was created in the first time .
AND, the problem is , after i did this, i cannot run program again , lol, even uninstall it and reinstall it, im ghosting my windows back for fix this problem ., .. so sad !
Btw, if i use Vobsub - subresync, its work good too, but , it doesnt allow me to create a matrix file for another sub, and i must do reconize one by one Sub !!! Omg, what a waste .
Any better program can convert Sub with idx to Srt(
Omg, after back up my Windows, i can run Subrip 1.71 ONLY 1 time !!! After the first time, windows always report error when i click on subrip icon ! Omg, i dont even know what is going on rite now,
But some can send me an old version of Subrip !? I think i have some conflict problem here but dunno what exatly it is ?!
Somebody have the same problem with me ? im Using windows XP Sp 1(
The character matrix is for one typeface only. It'd be plain luck, if 2 different DVDs have the subtitle rendered in exactly the same typeface. Only time there's any real point in saving the character matrix is when you have a >1 DVD set, like a Futurama season, or something like that.
Why SubRip doesn't work well with XP I cant tell you, but on my system, it works about once out of 3 tries. Seemingly completely at random, it crashes right at the start, but now and then works without any problems. Strange indeed.
/Mats
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 04:23 -
converting sub/idx to srt
By scarlac in forum DVD RippingReplies: 3Last Post: 9th Dec 2009, 07:26 -
How can Icreate 1 idx/sub with several srt?
By moryjingelbert in forum SubtitleReplies: 1Last Post: 15th Feb 2009, 14:42 -
IDX/SUB to SRT
By anirban in forum SubtitleReplies: 12Last Post: 5th Dec 2008, 21:05 -
Converting sub and idx subs into srt
By peyem in forum SubtitleReplies: 1Last Post: 4th Apr 2008, 18:23
