i used TMPGEnc dvd author and i did it the way the guide says: load the vob and save to hard drive. my problem is that i can play the mpeg on my computer and it only has audio in the left side and when i drag it inot any program like ulead or cool edit there isn't any audio at all. i thought it might have been that i selected the wrong channel or whatever when saving it but there is only one to select from. any help would me great.
Results 1 to 12 of 12
my aim is vi0lentjuggal027
I'm not familiar with Cool Edit, and you didn't mention which Ulead Program you are using, but I'm willing bet you're having codec issues. Does your DVD have AC3 audio? (You can use Gspot to check the file on your HDD.) Does your software support AC3 audio? Have you tried re-installing the codecs?
Hope this helps. Maybe someone else will come along with more precise answers.
Good Luck! -
Does the original Vob only have audio on the left side? I have a cheap VCR and it only puts out mono so all the DVD's I make with my recorder are like that. I have to redo the audio on every one.
the original both audio in the left and right. how do i get the ac3 plugin or from where?
but how can i hear teh audio when i just play the file but through nothing else?my aim is vi0lentjuggal027 -
the original dvd has only left audio so never mind on that issue but i still can't get any audio from any program i use besides just watching it in my media player.
neither the codec or the plugin made it work. do any of you guys usually rip from dvd to mpeg and try it in ulead video studio, if so tell me how to do it right. or should i just find another method, i'm trying to edit the video.my aim is vi0lentjuggal027 -
Originally Posted by boldego
Some versions of Ulead Video Studio accept AC3 audio, and some don't. Why don't you download Womble MPEG VIDEO WIZARD (30 day free trial) and see if your file works. MVW is a great MPEG editing program, and right now they are offering a discount coupon toward the purchase.
Good Luck! -
Originally Posted by vi0lentjuggal0
i tried converting another dvd and the same thing happens the file can play with audio but if i drag into any program there isn't any audio. do you think i need to download a plugin or codec for those programs or can i convert it some way to make it work. please help me out guys this is killing me.
after it converts though the and it says add clip and shows you all that info, the audio says no audiomy aim is vi0lentjuggal027 -
the only way i got it to work was to extract the audio off the original vob and join it with ulead, is there a better way?
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 08:32 -
Making a DVD compilation - MPEG2 to DVD problem
By Dingler in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2009, 13:40 -
DVD to MPEG2 Transport Stream audio sync problem
By elba in forum Video Streaming DownloadingReplies: 12Last Post: 23rd Oct 2008, 02:09 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 17:25
