  1. im not sure exactly where to put this so ill put it here and another post on another video site, but when i go to a folder full of
    .ogm's or .ogg's (i forget which they are, i deleted them right away cause i ddint want that problem to occur over and over)
    i get an error with WIndows Explorer and it shuts down (it closes all the windows of folders open) and then the startbar goes away for a few secondsa nd everything refreshes
    any clue what this may be?
    Dec 2004
    Australia
    Not sure that MS's thumbnail shell extension works for ogg/ogm's. If it does then that could be it.
    What filters do you have installed for ogg/ogm playback?
    Illiminable's, Radlight's, Tobias' or Gabest's?
    For ogg's Tobias' or Gabest's only support vorbis and Illiminable only has limited ogg support.
  3. i have :
    ogg mux 0.9.4.2
    and
    oggdropxpd 1.5
    both came with tsunami filter pack
    Dec 2004
    Australia
    Those aren't used for playback, so I can't see how they could be the cause.
    Anyway I think Tsunami installs Tobias' original filters. So I guess try uninstalling them and installing say Radlight's ogg/ogm filters instead. Tobias' filters haven't been updated in years.
    Also above should read "Illiminable only has limited ogm support".
  5. its not during playbcak though when the error happens, its as soon as i opent he folder that contains the .ogg files or .ogms
