Ok. I downloaded an mpg file. It was in PAL. I used Ulead to make it NTSC format. I then burned the mpeg NTSC onto a CDRW. I used Ulead and created a VCD. I have a KLH DVD-221 player. It wont read the disc. I took the disc to work and tried it in a Toshiba player. It wont read the disc. I tried burning it with Nero. It still isnt working. I am new at this but i cant get it to play on my PC either. The player i use for my CD's is Windows Media Player. I cant figure out what i'm doing wrong. I have read all the HOW TO stuff on this site but this disc should be playing. The mpeg i am putting on the disc is fairly short. I wanted to test it. PLEASE HELP
maybe your DVDplayer and your office DVDplayer doesnt support CDRs check the DVD players list on the left and check
My DVD player is said to support CDRW by the list. I have played a VCD of Star Wars before so i know it can play. Can you go over the basics so i can check to make sure i have done eveything right. If my mpeg is in NTSC and i burn it directly to a disc like that is it supposed to play or did i miss something?
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 19:04 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 13:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 01:34
