looking to buy some dual layer dvd's where is the cheapest place to buy them at??
i bought a three pack of verbatim's 2.4 x dvd+r DL for 20.93 with free shipping from radixgear.com.
was that cheap and what is the best place to buy them from??
i am pretty sure their cheaper somewhere else someone has to know of a better place then the place i mentioned..
CompUSA sells them for $19.99 for a 3-pack. Staples has them for $24.98. However, if you go to say Staples, or any other store that can do price match, you tell them that CompUSA sells these same DL DVD's for $19.99. Staples does 110% price match, so you'll end up getting DL Verbatims even cheaper at Staples with price match than at CompUSA. I did that already a few times - I saved on gas (ComUSA is quite far from here) and also got them even cheaper. So I think this is by far the cheapest you can go.
Best place for a layer break with DL DVD+R?
By hiimbored in forum DVD RippingReplies: 1Last Post: 26th Nov 2008, 21:18 -
What's the best place to buy a dvd recorder?
By BrokenOne in forum DVD & Blu-ray RecordersReplies: 43Last Post: 13th Mar 2008, 23:44 -
CHEAP Dual Layer DVDR Blank Disc @ Best Buy: I can't find that thread again
By Scooter_NJ in forum MediaReplies: 9Last Post: 11th Oct 2007, 16:42 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 10:36
