so what would you buy from svp the verbs or infinites ???
Results 31 to 34 of 34
They should be the same disc - in theory it's appearance. If the Infiniti are bright pink with yellow text and pictures of fluffy kittens all over it, I'd buy the Verbatim...
got an email form svp thay said the only diffrence are the verbs has somthing called AZO protective dye or somthing whats all that about ???? never herd of it
HI all right i found out that alot of people like ty disks but i find thay are just to much money for me so what would you pick from here in order
http://www.blankdiscshop.co.uk/acatalog/dvd-rprint.html
1.Verbatim "Full Face Printable" (16x) DVD-R in Spindle Tubs of 50
£25
2.2 packs Infiniti Inkjet Printable (16x) DVD-R in Spindle Tubs of 25
£16.50
3.2 packs Datawrite Titanium "Printable" (16x) DVD-R in Spindle Tubs of
£16.50
all above use MCC03RG20 dye the only diffrence is that the verbs have AZO in the dye what ever that is and the printable surface area but what would you pick
or would you pick
Photo Printable Verbatim "Full Face" (8x) DVD-R Disc in Spindle Tubs of 50 which use the MCC 02RG20 dye
or the Ritek Silver Printable (8x) DVD-R in Spindle Tubs of 50 that uses
RITEKG..05. dye
I have a pionner a107 i want the best disk for my money out of these options i can only write up to 8 speed i dont know which is better the
MCC 02RG20 or the MCC03RG20 dye or the ritek G05 dye
now if you do say the MCC03RG20 is the best out of these whi9ch of the three would you pick that uses this same dye i can not understand why the verbs use the same due as the Datawrite and Infiniti but are £10 cheaper ????????????????
all i want is the best disk to use the most compat with dvd players and the best made disk i hope you can help
So what brand pf DVD blanks is everyone using now that Verbatim sucks???
By progrocktv in forum MediaReplies: 82Last Post: 30th Oct 2010, 13:08 -
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 01:14 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 20:18 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29 -
.avi files -- Help I'm burning lots of DVD blanks...
By TorreyGuy in forum MacReplies: 6Last Post: 11th Jul 2007, 08:58
