Poll: Maxell or Ritek/Ridata CDR: Which one is better/most used?
Be advised that this is a public poll: other users can see the choice(s) you selected.
  1. Which one is better/most used, Ritek or Maxell CDR
  2. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    Ritek makes Maxell CD's.
    At least all the ones I've seen have been Riteks.
    May 2004
    WA state USA
    LOL
    most of ur cd-r's will be made by cmc
    i once has a sindle of ty cdr's i liked those, i like my cmc media too for cdr, as long as u got a good burner then its all good
  4. I can get either 100 Ridata (I'm assuming this is Ritek) CD-R's for 23 bucks, for 30 Maxell for 29 bucks. (Canadian pricing)
    I've never used Ridata CD"s before.
  5. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    If you get the Maxells, you will probably find a Ritek media code on them...like I said above.
    So, you are probably better to buy whatever is cheaper becuase they are more than likely the same disc. Personally I would go with Fuji (TY) or TY branded discs. They aren't much more money and are alot better.
