Please can any one help me on how to put more than one download onto a dvd disc? I have nero & dvd shrink but cant see how to do it.
Any help will be great
Not sure what you mean.
Do you mean more than one movie on a dvd disc. Try an DVD Authoring software. or use dvd shrink in re--author mode. Though you will notice heavy quality loss if you sqeeze two dvd movies on a single disc. -
Too much info missing in this thread.
What kind of downloads? AVI, MPG, WMV, ISO, VOB etc...
What kind of DVD? Data or playable in most DVD players? -
Don't.
Converting downloaded dvix avi files to MPEG-2 is a guaranteed way to produce crummy-looking video. Divx avi is incompatible in every possible way with MPEG-2 -- different frame resolution, different encoding method, typically a different soundtrack encoding method, everything's different. Plus, encoding at such low bitrate divx ruins the video so badly you can't recover it. Even after 10 or 12 hours of VDub filtering on a fast P4 3.2 Ghz machine, the output still looks like junk. -
Sorry you've had such a bad experience but I've got some pretty nice DVDs I made from XviD/DivX files.Originally Posted by spectroelectro
I downloaded a tv series and at the mo it all on seperate discs, I just want to put them onto one disc. They have meen converted from avi files & put onto single dvd discs. I have dvd shrink 3 but havent got a clue what to do, and everytime i try to put them onto a single disc in shrink it seems to loose the first one i put into it & shows the second only.
I assume that you have 12 1GB VOBs/ISO images. The most you are going to fit on one DVD is 4 episodes. If you want to fit all 12 episodes on one disk, you will need to convert them back to XviD and burn a Data Disk that is playable in a DivX/XviD DVD Player.Originally Posted by kaz
Here is a list of guides for DVDshrink.
https://www.videohelp.com/guides.php?tools=155&madeby=&formatconversionselect=&howtosel...or+List+Guides -
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 16th Feb 2012, 23:54 -
Can you put DVD quality (and structure) video on a Blu-Ray disc?
By rayden54 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2011, 02:17 -
Noob: How to put to DVD programs on to one DVD disc?
By peggypwr1 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2009, 13:48 -
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 10:09 -
Put severeal AVCHD Mini-Disc onto a DVD-5: How?
By gekko_video in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Apr 2008, 15:35
