All my source video is shot on Sony Digital8 and captured via firewire to Premiere Pro or Premiere Elements. Once I have that .avi (I guess it's uncompressed raw) I try to export a Microsoft AVI with the mpeg4v2 codec and all the videos look horrible, with blockiness and smearing. I've tried adjusting bitrates to no effect. I don't like this codec but I'm in a corporate environment where I can't install DivX, etc. on a bunch of workstations. Should I just stick to mpeg1? My old Premiere6.5 used to make some at least average looking MSmpeg4v2's.
Any advice is GREATLY appreciated!
--c0r3file
If your video was shot on digital 8 it won't be uncompressed raw RBG, it'll be 5:1 compressed Type 2 DV avi (i.e., 80% of the video information has been thrown out ). Not to worry, Type 2 DV is still an excellent video format even though it does toss 80% of the video info. Ebert is probably right, you should keep the video in the native Type 2 DV avi in which Premiere captured it and try exporting directly to MS mpeg4.
That said, MS's mpeg4 ain't that great. Xvid gives a lot better results and it's free open source. Bear in mind you will get blocking and smearing with any mpeg-4 codec. MPEG-2 seems superior to all the mpeg-4 codecs I've seen insofar as mpeg-2 becomes transparent if you ramp up the bitrate high enough. That doesn't seem to be the case with MPEG-4 codecs, alas. Also, all the mpeg-4 codecs I've seen produce results that look significantly worse on a TV screen than on a computer screen for some oddball reason.
Horrible audio synch
By rocks911 in forum Video ConversionReplies: 9Last Post: 13th Jan 2012, 05:50 -
Anyone please tell me how to convert xvid to mpeg4-part2(mp4v2)?
By xjohn in forum Video ConversionReplies: 11Last Post: 18th Mar 2010, 10:02 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
Subtitles !! work horrible !!!
By philparis in forum ffmpegX general discussionReplies: 6Last Post: 27th Feb 2009, 17:44 -
why is my video quality so horrible?
By crazymonk848 in forum Newbie / General discussionsReplies: 10Last Post: 21st Mar 2008, 14:23
