These two apps might save you some grief one day:
RDILLY is a one click registry backup util. Just click on it and it will create a dated folder with a current snapshot of your registry. You can even run it from the command line as a batch file, timed script, etc. "Unlike NTBackup's system state backup of the registry, the HARDWARE hive is included in the backup folder."
http://www.joejoesoft.com/rd.php
Windrivers Backup will back up your hardware drivers, .inf files, etc to a folder you specify. Nice to have if you need to do a reinstallation of a corrupted driver.
http://freespace.virgin.net/john.mcneish/wdrvbck1.exe
Results 1 to 1 of 1
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
Driver backup software
By Tbag in forum ComputerReplies: 2Last Post: 2nd Mar 2010, 18:10 -
Registry Cleaner
By BLSAMPLES in forum Newbie / General discussionsReplies: 5Last Post: 11th Oct 2009, 09:45 -
Registry problem?
By alintatoc in forum ComputerReplies: 8Last Post: 4th Jul 2009, 17:23 -
Registry corrupted
By zoobie in forum ComputerReplies: 9Last Post: 11th Jun 2007, 11:57
