hi all
i converted part of a movie which was a divx (688megs) ive changed it into a vcd (pal) BUT the audio is about 5-10 MINS out ,,ive never came across this problem before ,,well not that much difference anyway
how can i sort the problem out??
if its easy enough to answer and somebody dont mind could u ICQ me on 78504701 please
thanks and regards
Nifty
the best way to handle a divx is to convert it to na avi using vdub and either huffyuv or picvideo codec, then cut out any bad video parts using vdub, one bad video part will through the sound off for the rest of the movie. when the avi is perfect, then use vdub to seperate the audio in eav 44,100 format, then encode with tmpenc using the avi as video and the wav as audio, should come out great.
thx for replying Sommersby
there are a couple of things i dont understand tho
1.convert it to na avi using vdub and either huffyuv or picvideo codec???????
thing is the picture is Excellent quality...1 of the best ive seen in fact
i think im goin wrong somewhere when im ripping the sound out....
what is the best programme for this? or is that what u meant by huffyuv? as i dont know what huffy is could you please explain...or better still are u on icq??
thx again for replying
regards
Nifty -
Nifty,
You like people to icq u, huh? Well, too bad, don't know how to use it. Haha ^u^ Suggestion to you is use TMPGEnc. and the external audio encoder "TooLame" to encode your audio. Then use TMPGEnc. to mux your video and audio together. Should go out great. Good Luck Jordan
PS. Or you could try just muxing the audio from the original avi with your encode video only if the audio setting has no changes. -
Your not going to lose anything by converting it to avi using huffyuv. It is a loseless codec, you could try using toolame and doing it direct with tmpenc, but I have never had very much success doing it that way, on most downloaded divx files I can't even get tmpenx to open them, some say they open but no video, and when they do open correctly all it takes is one glitch in the video and your out of sync. the method I described yields a good vcd about 99% of the time, it adds a couple steps but at least you don't have to start over from the begining all the time.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
