Hi to all,
I am searching for a command line, mpeg2 cutter, preferably open source. I need to be able to give a terminal command like "mcut mike.mpg -time:5" and this will output the first 5 secs of mike.mpg in a mpeg2 video file.
I do not want to decode and reencode the file because I want it to be fast.
I've searched a lot and all I could find is DVTool and Dark Avenger's MPEG2Cut, which are not command line, and TMPGEnc which cannot handle all mpeg2 files.
Does anybody know of any other program?
Also, I know some and I have more then enough time in my hands, so I'm thinking of writing such a program from scratch. Do you know any good c libraries I good use? Remember, I do not want to decode/reencode but to work directly with the mpeg2 file.
Thanks in advance.
PS: I know almost nothing about linux. I've been using debian for less than a month- but I'm learning. So please keep you answers simple linuxwise.
TMPGEnc? Linux? What about mpgtx? Seems like there are both Windows and *nix versions available.
/Mats -
Well, actually I'm searching in both platforms, but since commandline and open source are needed, i lean on linux.Originally Posted by mats.hogberg
Concerning mpgtx, I know it, but its site says:
"<< splitting and joining of MPEG 2 video files is experimental. (read "will work only in your wildest dreams")" -
Well, it's worth a try, at least?
/Mats -
Well you were right. It does very good mpeg2 cutting. There are only some problems with transport layered video. I'll look into it.
Thanks a lot.
PS: know any other cutter besides this?
Convert multiple mpeg2 to wmv with command line!!! Help pls!!
By orlroc in forum Video ConversionReplies: 5Last Post: 15th Dec 2009, 23:18 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44 -
Joining Mpeg2 files from the command line
By roden in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 09:02 -
MPEG2 > RAW AVI via Command Line
By jwoodsfsp in forum Video ConversionReplies: 13Last Post: 30th Jul 2007, 20:36
