    Apr 2005
    Beside My Computer
    I am having a problem with the DVD stopping where the assets join.
    I used SVCD2DVD 2.0 RC8 on a movie with 3 bin files.
    I clicked on Assets, then proceeded to select my assets, Bin1, Bin2, then Bin3.
    I then used the Quick DVD & Burn method. After the program was finished preforming its magic I then put the DVD-R in my DVD player, started watching the movie and then when it got to the end of which would have been Bin1 it stopped, I had to push next on the remote to get the movie to continue into Bin2, same thing at the end of Bin2.
    I then tried the DVD-R in my computer using PowerDVD same thing
    Am I doing something wrong? I thought that the DVD-R was suppose to play without stopping at the merging points.
    I also tried another movie with 2 bins same result, any help resolving this matter would be greatly appreciated. 8)
  2. What you need to do is put all three assets into the same vts and then click the author dvd button, witout using the dropdown menu, and then you can choose to burn or not from the resulting pop-up screen. In order for assets to be joined they must be in the same vts. I'm sure if you checked the contents of your dvd you would find there is only vts_01_0 vts_01_1 and so on and then vts_02_0 vts_02_1 and also vts_03_0. If the assets are joined properly you would only have the vts_01 movie files. I hope I've made myself clear.
    Apr 2005
    Beside My Computer
    Thanks PredatOr,
    I am having a problem, when I try to drag and drop my assets into the VTS Layout window nothing happens, so when I click on Author Your DVD, the pop up box says No titlesets to author
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Originally Posted by |nsight
    Thanks PredatOr,
    If you start with bins then you need to do "Assets->Extract...." first. This will turn then bins into mpgs then you can follow PredatOr's instructions.
    If you want to use "Quick DVD" then ensure that the bins are in the same folder & have a common basename: like moviecd1.bin moviecd2.bin moviecd2.bin. If this is the case "Quick DVD" will also put them in the same VTS (TitleSet).
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If this still gives you issue (using a sinlge VTS) then select the merge titles option in the settings.
    Apr 2005
    Beside My Computer
    Thanks ChrissyBoy,
    Worked like a charm, much appreciated.
