I have purchased a used Prime Image TBC for a very good price, $100. The model number is TBC.SYNC+ No numbers. The TBC.SYNC+ uses BNC connectors. I have puchased BNC-->RCA adaptors.
My main query: This older TBC has quite a few options. Which do I use for basic TBC functions (I am transferring old, jittery video tapes to DVD via a USB capture device). Anyone familiar with the following functions? Suggestions on how to hook up the VCR?
The back of the unit has TEN BNC connectors labeled as follows:
GEN LK (two of them)/ 3.58/ DOC/ ADV V/ TBC V/ VID OUT 1/ VID OUT 2/ VID IN/ VIDEO FREEZE (off/on switch)
The front on the unit has the following knobs:
VIDEO LEVEL (connected to a LED to display video level)/ SETUP/ CHROMA/ HUE/ STROBE OFF-ON/ FREEZE/ POSTER/ SEPIA/ MOSAIC/
OK, so what do I do with this thing? Do I feed the video into the VID IN and (obviously) out via the VID OUT? Then what is the TBC V for? Is the VIDEO LEVEL the TBC?
Any advice from anyone who has used PRIME IMAGE units similiar to this one?
Cheers,
adcvideo
Results 1 to 1 of 1
Advice on File Formats and TBC for 8mm & VHS
By mrees in forum RestorationReplies: 15Last Post: 19th Jun 2011, 22:52 -
Prime Image Freeze II question
By pgoelz in forum Capturing and VCRReplies: 9Last Post: 12th May 2011, 18:39 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58
