Hi all, I couldn't find this information anywhere, and my searches in the forums turned up nothing. I was just wondering how I would be able to create a 2-4 hour dvd on a 4.7 DVD-+R. Films like Lord of the Rings or just family home videos are the kind of material I would put on the DVD. As it stands, the max length I can create is 2 hours. How can I increase it and what programs should I use? Right now I am using Intervideo WinDVD Creator 2. I don't care about dropoffs in quality, I just want to know how it is done, if it can be done at all. Thank you.
If you are just backing up a video, try DVD Shrink. Other than that, you use an MPEG-2 encoder and adjust the bitrate to the time of the video.
If you look to the left in 'Tools' you will see several bitrate calculators. They will show you the settings needed to encode whatever length of video you require to fit on a DVD.
However, the lower the bitrate, the lower the quality. You might want to do some more reading.... -
4 hours is a bit on ask. 2 hours is about the practical limit for single layer disks. If you do want to put 4 hours on from VHS sources, you could try half-D1. This reduces the horizontal resolution 50%, but plays back at full frame. As VHS is pretty soft to begin with, you won't notice the difference. You could then get 4 hours at OK quality.
I would suggest getting a good encoder - tmpgenc, procoder express, CCE basic are all good. procoder express and CCE basic are substantially faster than tmpgenc, but you should test each of them against a sample of your footage and see which you prefer. You could also consider the free encoders - Quenc and HC.
Get familiar with the bitrate calculator on this site (look it up in the tools section) as well.Read my blog here.
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 14:35 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 07:23 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 21:28 -
4 half hour eps on one dvd?
By motleycool in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2007, 00:18
