Yep, I updated the firmware in the Plextor drive to the latest version.
So I insert a blank CDRW into the drive, and it gets identified by Toast 6.07 as a DVD-RAM. However, when the disk is mounted on the desktop, the icon says "CDRW".
I tried running the latest version of Patchburn, that didn't help.
Also, when I try "Erase Disk" on a CDRW, Toast says "Illegal Operation" and "Connection is unstable." I don't see why since it burns DVDs just fine, and it reads CDs well too.
I'm running OS X 10.3.8 on a G4 and the Plextor drive is an internal unit.
I tried several CDRWs, some blank, some used. Toast always identifies them as DVD-RAMs or DVD-ROMs depending on whether they are erased or not. Funny thing is, Toast 6 has no problem identifying CDRWs correctly with the original factory CDRW drive, which I removed to install the Plextor drive.
Is anyone else having this problem?
Thanks.![]()
It's a problem with Toast. Dragon Burn works OK and once run, then Finder burns and Disk Utility erases work OK also.Is anyone else having this problem?
See this and this discussion threads on the Toast BBS at Roxio.
See this discussion thread at the Plextor group of CDFreaks BBS. Note -- some denizens start foaming at the mouth upon reading "Mac".
PC "thinks" burned media is blank
By joelson in forum MediaReplies: 12Last Post: 28th Jan 2012, 19:19 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Vista thinks dvds are wrong region...
By imaginaryduck in forum Software PlayingReplies: 8Last Post: 1st Oct 2009, 01:01 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
Premiere Elements thinks the project is longer than it really is
By cdig04 in forum EditingReplies: 4Last Post: 22nd Apr 2008, 09:34
