Results 1 to 10 of 10
    Mar 2005
    Toronto
    I have DTS file i want to convert to mp3 iv demuxed it with avi_mux.
    Or is there a way to remux the converted avi with .dts audio?
    Thanks in advance.
    Mar 2005
    Toronto
    How do i convert this .dts to .mp3 or any format playable on the dvp642 with no quality loss?
  3. Banned
    Mar 2005
    U.S.
    xilisoft video converter i used can rip dts file to other format. but i am not sure, suggest you to download to trial.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
    Apr 2005
    Belgium
    With besweetgui and windvd can you convert your dts file into another file
    I can write a guide but my English isn't perfect.
    But you must sure you lose ALWAYS quality.
    It's logical , but dts to 5.1 ac3 is the min quality losing.
    Hypercube transcoder is an another tool for trying to convert
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Check doom9 - there's an entry from 04/25 that claims that "Auto Gordian Knot 2.07 supports DTS audio in AVI files" that might help.
    /Mats
    Dec 2004
    Australia
    Probably means DTS in an avi, not DTS converted to mp3 and then stored in an avi.
    Foobar2k is another solution. Make sure that you have the DTS input plugin.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, it does. In reply to
    Indicates that at least muxing is possible (which in turn indicates that remuxing should be possible).
    /Mats
    Dec 2004
    Australia
    DTS muxing in avi has always been possible. Well at least it has for ages, since I think it was Gabest wrote the first DTS parser filter for playback and AlexNoe added support in AVIMuxGUI. It was a long time ago though.
    I just re-read though and they demuxed the DTS stream from an avi and they want to remux it?
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Seems so to me - maybe CrisCr0ss might enlighten us? His second post tells me that it's for a standalone, and I'm not sure if the dvp642 supports DTS in AVI...
    Anyho, a quick google for "DTS to wav" turned up this as the first link... Once you've got the wav, you can encode it to whatever format you want.
    /Mats
    Mar 2005
    Toronto
    i managed to convert using autogk...
