I was just wondering if my dvd plays dvds or cds as data discs,
Like for example I put 2 mpgs then I select from the menu the data file, and play it,
Will I be able to do that ?
I got a pioneer dv-360
https://www.videohelp.com/dvdplayers.php?DVDname=pioneer+dv-360&Search=Search&country=&...y=Name&hits=25
according to the dvd player database...
mpegs no..
music (mp3/wma) yes..
doesnt mean you shouldnt giv'er a whirl.. its only 1 dvd-r.
i've got a pioneer dv-270 and it wont play mpeg files burned on to a dvd-r. -
Burn it to a dvdr and give it a try.
Burning Data Program on DL discs?
By PowerFalcon in forum MediaReplies: 2Last Post: 27th Jul 2011, 07:58 -
HI-DEF 720p DATA DISCS
By artmcclin in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Jun 2009, 10:51 -
Which specifications should I be looking for to play my data discs?
By K_Kat in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th Jun 2009, 10:53 -
Xbox 360 no longer plays mpg?
By David97 in forum Video Streaming DownloadingReplies: 4Last Post: 15th Dec 2008, 07:01 -
Need felp converting MKV file so it plays on Xbox 360
By wwervd316 in forum Newbie / General discussionsReplies: 6Last Post: 7th Mar 2008, 22:29
