  1. So I just converted these .bin / .cue files into two .iso files. Toast is set to Multitrack CD-ROM XA, but when I try to drag the .iso files into the window, it gives me the following error.
    "The length is not a multiple of the sector size."
    I went ahead and burned it and ended up with a coaster (it asks to re-initialize the CD when I re-insert it after burning).
    Help!
  2. I use Toast 5 Titanium to burn VCDs all the time. To burn from bin or iso select Other - Video CD then click select and choose VCD Image. Or you can just drag the image into the window after you select VCD. For .raw files select multi track CD-ROM XA and drag the tracks in order onto the window.
    Let me know if this works for you.
    DFG
  3. Selecting the .iso files either through the Video CD or CD-ROM XA options doesn't work for me.
  4. What's in the image files, mpeg1 or mpeg2 or other?
  5. those .iso files contain mpeg-1. They're VCDs.
  6. I think the problem may be the .ISO files. There is no need to convert the .BIN to .ISO since Toast will burn the .BIN images directly using the VideoCD option. At least that's what I do in Toast 4 on my Mac and I assume Toast 5 is similar. I create .BIN images in VCDEasy or TSCV on my PC and burn them in Toast 4 on my Mac with no problems.
  7. Toast does not support the .iso format. Just set up Toast for Video CD and drop the bin file on it.
  8. OOOPS,
    Toast does not read EasyCD *.cif files. I haven't tried using the *.iso file. Dropping a *.bin file onto the Toast window when it is set for video CD seems to work fine.
