I have been trying to encode a .asf to divx using FFmpegx, and for video, the results are fine, but for some reason every time I try to encode the .asf which has wmav2 audio it will not appear on the finished file. I have tried every audio encoding option, at both the asf's sample rate (44100) and the default (48000). Does FFmpegX handle wmav2 audio from .asf files? If so, what is the proper audio encoding scheme.
More detailed info from FFmpegX Progress. The info window says that there is no audio stream found, even though there is one on the file.
Encoding started on Thu Apr 14 11:38:43 ADT 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x4f0f33a
ASF file format detected.
Too many video packets in the buffer: (3532 in 8390280 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
ASF: No audio stream found -> no sound.
VIDEO: [2VMW] 352x240 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:6 fourcc:0x32564D57 size:352x240 fps:1000.00 ftime:=0.0010
Requested video codec family [wmv8] (vfm=dshow) not available.
Enable it at compilation.
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=352 h=240]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Requested video codec family [wmvdmo] (vfm=dmo) not available.
Selected video codec: [ffwmv2] vfm:ffmpeg (FFmpeg M$ WMV2/WMV8)
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 352 x 240 (preferred csp: Planar YV12)
I7:0/
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (352x240 fourcc=58564944 [XVID])
[wmv2 @ 0x6158a0]I7:0/
I'm not sure what you mean by 'not supported', I've had no problem encoding the video from the .asf I mentioned into mencoder divx, but as I said, the result is a video file with no audio. Using the Movie audio to mp3 option and by selecting Invert Mapping I was able to capture the audio track from the file. I am also able to encode the video from this .asf into mencoder divx, but the resulting video file has no audio. I haven't tried the Add Audio feature yet to combine the captured audio and encoded divx video but I believe that will solve my problem.
Thanks anyway, very fast support, amazing app.
Video and audio did not encode what can I do?
By IYIasteI2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2011, 10:00 -
How to encode audio to different fps?
By mrjust in forum Newbie / General discussionsReplies: 9Last Post: 16th Mar 2010, 21:07 -
Cannot Encode, Audio Error
By kidcash in forum Video ConversionReplies: 4Last Post: 19th May 2008, 02:18 -
Trim audio without re-encode
By pchan in forum AudioReplies: 3Last Post: 17th Sep 2007, 08:29 -
Encode to audio with VBR?
By GangstaRap in forum Video ConversionReplies: 2Last Post: 27th May 2007, 08:56
