Results 1 to 28 of 28
  1. Hi everyone,
    Usually when I have a few .avi files I encode them with TMPGenc Xpress into .mpg files, and then use TMPGenc DVD Author to put then all on a DVD. I burn them with Nero Burning Rom, and incase I get an error message, which up until happend very rear, I use DVD Shrink and make the DVD files into an .nrg file and then burn the image file with DVD Decrypter.
    Recently I have been experiencing a very strange problem. I cannot burn the DVD files with Nero Burning Rom, neither can I burn the .nrg file with DVD Decrypter.
    The error message that I get with Nero is the following:
    Burn process failed at 2.4x(3,312kb/s)
    The error message that I get with DVD Decrypter is the following:
    I/O Error
    Device: [1:0:0] Sony DVD RW DW-U50A 1.5b (E (ATA)
    ScsiStatus: 0x02
    CDB: 2A 00 00 00 08 C0 00 00 20 00
    Interpretation: Write (10) - Sector: 2240-2271
    Sense Area: 70 00 05 00 00 00 12 00 00 00 00 21 02 00 C0 00 02 00 00 00 00 00 00 00 00
    Interpretation: Invalid Address for write
    I have tried all kinds of different avi, mpg, DVD and nrg files, so it is not that I am getting this errors from the same file, but from different ones.
    Can anyone please advise me on what to do?
    Thanks, any help is really appreciated!
    Aug 2004
    Try to burn with TMPGEnc DVD Author, I always do that when finished authoring.
    Never had a problem
  3. OK, thanks, I will try it. I would really like to know why I cannot burn with Nero anymore, why am I getting these error messages?
    Thank you
    May 2003
    Peterborough, England
    I've had the Invalid Address for Write error message with a batch of dodgy discs. Try a different batch or make.
  5. When burning with TMPGenc DVD Author, I get an error:
    An error occured during reading...
  6. I am not sure what you mean, Richard_G...
    I tried burning the image file with a lower speed with DVD Decrypter but I get the same error message.
    Any suggestions are really appreciated
    May 2003
    The discs I was trying to burn were faulty. Try burning to a disc from a different batch or manufacturer. The ones I had the problem with were some Ritek G04 discs which I had been using for a long time with no problems. Around the time I started to get these errors, a number of other people reported problems with Ritek G04 discs. Changing to a different make cured the error.
  8. Thanks for your help!
    The disks that I am using are GIGATAIN DVD+R and have burn more than a 100 DVDs, never had a problem. I have another make that I will try with and let you know.
    Thanks!
    Aug 2004
    Toronto, Ontario, Canada
    I agree it can be the media. When I started having burning & verification failures, it always stopped when I switched media, and it always happened on media that had worked fine before. I have a cake of Ritek -R where some work perfectly, some burn with errors, and others won't finalize after burning.
  10. YES, it worked! It burned perfect with Nero using DVDs from the make RIDATA DVD+R. The question is... is this a one time thing... a coinsidence... As I said with the make GIGATAIN DVD+R I have burned over a 100 DVDs, so how come now suddenly I get these errors... It's just strange that these make of DVDs worked for a long time and now suddenly they don't...
    By the way, in the mean time someone from another forum recommended me to use DVD Santa, so I downloaded it and the burning process was 100%, but it didn't play in my DVD player, just made some strange noise and nothing happend (I used the DVDs that I have always been using GIGATAIN DVD+R)... so after all it is the DVD manufacturer.
    Thank you all for the help!
  11. Hi eveyone,
    I am facing another challenge with burning DVDs... I cannot burn on the second laptop that I have. The thing is that I bought this second laptop in the US and I am based in Europe. Ever since I got it I have never been able to burn a DVD from a VIDEO_TS folder, I always had to convert it into an image file with DVD Schrink and then was able to burn it with DVD Decrypter.
    Now, as this laptop is running out of space I wanted to just burn movie files but as data, just to save space, and just to be able to watch the files on the laptop... just simple and easy to also save time with encoding, making the DVDs and then converting then into image files.
    I tried a few times to burn the data files on a DVD with Nero but every time just at 99% it fails. When I check the disks, they are 100% used but I cannot see any content on them. I thought that it might be the same problem with the DVD manufacturer, so I tried different kind of brands. I also tried moving the files into my other laptop, managed to burn a data DVD, but then I cannot see the files ones I insert the DVD into the second laptop. So basically I am stuck with no space on the seond laptop and have no way of getting the files off and burning then on a data DVD. I believe that to be able to view the data files on that second laptop, I do have to burn then on it, but I cannot... I really think that there is something wrong with the CD-RW/DVD-ROM / burner. And also I believe that it experiences a conflict, as it is a US laptop funcioning in Europe, may be...
    Just in case here are the specs from the second laptop:
    Sony VAIO K17 (PCGK17) PC Notebook
    Processor Intel Pentium 4 3.06 GHz
    Mobile Technology Wi-Fi Certified
    Installed Memory 512 MB (DDR SDRAM)
    Display 15.00 in. XGA TFT LCD
    Operating System Microsoft Windows XP Home
    Processor Type Pentium 4
    Processor Manufacturer Intel
    Processor Speed 3.06 GHz
    Processor Number 532
    Motherboard
    Bus Speed 533 MHz
    Display Tech XGA TFT LCD
    Display Size 15.00 in.
    Display Color Support 24-bit (16.7 million colors)
    Display Max. Resolution 1024 x 768
    System
    Expandability 1 x Type III PC Card Slot, 1 x Memory Stick PRO
    Expansion Ports 3 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, Parallel Port, RJ-11 (modem), RJ-45 (NIC)
    Hard Drive
    Hard Drive Capacity 80 GB
    Hard Drive Rotation Speed 4200 RPM
    Storage Controller Type EIDE
    Memory
    Installed RAM 512 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 1024 MB
    Installed Cache Memory 512 KB
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 24x (CD) • 4x (CD)
    Optical Drive ReWrite Speed 10x (CD-RW)
    Video
    Graphic Processor ATI MOBILITY RADEON IGP 345M
    Audio
    Audio Input Type Microphone
    Audio Output Type Headphones • Sound card
    Can anyone please help me or advise me on what to do?
    Thanks, I appreciate it!
    May 2003
    You won't be able to burn DVDs on the drive in that laptop because it isn't a DVD burner. Look at what it says, it's a combo drive, a CD rewriter that can also function as a DVD-ROM (reader). It can't burn DVD disks only read them. The only way you can get the files off it would be to burn them to lots of CDs.
  13. Really, are you sure? So how come I can burn image files (nrg, img) with DVD Decrypter?
  14. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    good pickup richard
  15. On the stickers placed on top of the laptop it says:
    Integrated DVD+/-RW drive
  16. here are the specs:
  17. Sorry on the post above, it didnt manage to add a pdf file, here it is:
    http://esupport.sony.com/perl/model-documents.pl?mdl=PCGK17
    > marketing specifications > pdf
  18. Just wanted to let you know that I do have an external hard drive on which I copied all the files that I wanted to burn on a data DVD. That is how I managed to burn a data DVD from my laptop. But as I said the second laptop does not read the data DVD. And I do want to eventually take all the files off the external hard drive.
    Thanks for all your help!
    May 2003
    Motherboard
    Bus Speed 533 MHz
    System
    Hard Drive
    Memory
    CD / DVD
    Video
    Audio
    I don't care what you think you have or what the marketing blurb says you should have, you haven't. You have a Combo drive, a DVD reader and CD rewriter. It's in the spec that you posted. Have you taken that from the manufacturers documentation or has it been detected by Windows System Information? I suppose it's always possible that Windows is detecting it as a combo drive even though it is actually a DVD rewriter. What make/model drive does Device Manager list it as?
  20. The specs that I posted before are a copy of the sony vaio website. However on the manufacturer's documentation it says "Optical drive: DVD+/-RW drive", and the Device Manager says that it is a "Pioneer DVD-RW DVR-K12D".
    I am just confused as I still wonder how come I can burn image files...
    May 2003
    It looks like the Sony website is out of date then. The Pioneer DVR-K12D is definitely a DVD rewriter. Have you tried loading a blank DVD in the drive and simply dragging and dropping the files from the hard drive from within Windows Explorer?
  22. Well, at least we know now for sure that it is a DVD rewriter, thanks!
    I just tried loading a blank DVD in the drive and dragging and dropping the files from the hard drive from within Windows Explorer and it gives me the following error:
    Problem Copying
    Windows encountered a problem when trying to copy this file. What to you want Windows to do?
    Retry / Skip / Cancel
    I tried this a few time with various files and the error remains the same.
  23. In the mean time I did some research and here are a few links to other forums with posts from people who experience similar problems with their Pioneer DVD-RW DVR-K12D:
    http://forums.afterdawn.com/thread_view.cfm/195113
    http://forums.afterdawn.com/thread_view.cfm/188052
    http://forum.digital-digest.com/archive/topic/46894-1.html
    http://forum.digital-digest.com/showthread.php?s=&threadid=38999
    What I could make out of these forums is that it seems that its either the driver or the program that they are using for burning.
    I am getting another burning program at the moment and also trying to find where I can download the driver so that I can unstall it and reinstall it.
    Just in case here are the details from Nero Info Tool:
    Nero InfoTool 2.00
    Drive Information
    Drive : PIONEER DVD-RW DVR-K12D
    Type : DVD-R/RW Combo Drive
    Firmware Version : 1.10
    Buffer Size : 2000 KB
    Date : 03-12-26
    Serial Number : CLDL056837WL
    Drive Letter : F:\
    Mechanism : Tray
    Read Speed : 6 X
    Write Speed : 18 X
    Read CD Text : Yes
    Return C2 Pointers : Yes
    Read CD-R : Yes
    Read CD-RW : Yes
    Read DVD-ROM : Yes
    Read DVD-RAM : No
    Read DVD-R : Yes
    Read DVD-RW : Yes
    Read DVD+R : Yes
    Read DVD+RW : Yes
    Read Digital Audio : Yes
    Read CD+G : No
    Read VideoCD : Yes
    Write CD-R : Yes
    Write CD-RW : Yes
    Write DVD-R : Yes
    Write DVD-RW : Yes
    Write DVD+R : Yes
    Write DVD+RW : Yes
    Write DVD-RAM : No
    Buffer Underrun Protection : Yes
    Mount Rainier : No
    Modes : Packet, TAO, DAO, SAO, RAW SAO, RAW DAO, RAW SAO 16, RAW SAO 96, RAW DAO 16, RAW DAO 96
    Region Protection Control : RPC II
    Region : 2
    Changes User : 3
    Changes Vendor : 4
    Disc Information (F:\)
    Type : Blank DVD+R
    Interface Information
    Adapter 1
    Description : Primary IDE Channel
    Driver
    Description : System32\DRIVERS\atapi.sys
    Company : Microsoft Corporation
    Version : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Description : IDE/ATAPI Port Driver
    Attached Devices
    Description : Master: HITACHI_DK23FA-80
    Type : Disk Drive
    DMA : On
    Adapter 2
    Description : Secondary IDE Channel
    Driver
    Attached Devices
    Description : Master: PIONEER DVD-RW DVR-K12D
    Type : CD-Rom Drive
    DMA : On
    Autorun : On
    Adapter 3
    Description : Texas Instruments PCI7420 Integrated FlashMedia Controller
    Driver
    Description : system32\drivers\tifmsony.sys
    Company : Texas Instruments
    Version : 1.0.1.3
    Description : tifmsony.sys
    Attached Devices
    Description : MemoryStick or MemoryStickPro Device
    Type : Disk Drive
    Adapter 4
    Description : Standard Enhanced PCI to USB Host Controller
    Driver
    Description : System32\DRIVERS\usbehci.sys
    Description : EHCI eUSB Miniport Driver
    Attached Devices
    Description : HDS72251 2VLAT20 USB Device
    Type : Disk Drive
    Software Information
    Operating System : Windows XP Home Edition (5.01.2600 Service Pack 2)
    ASPI : Nero Aspi Library 2.0.1.56 Ahead Software AG
    Description : Nero Burning ROM
    Version : 6, 0, 0, 0
    Company : Ahead Software AG
    Version Check : Ok
    Hardware Information
    CPU : Mobile Intel Pentium 4 CPU 3.06GHz 3060 MHz
    Bus Speed : 133 MHz
    Motherboard : Sony Q-Project
    System : Sony PCG-K17(UC)
    BIOS : Phoenix R0104X1
    Memory : 446 MB
    Sound : Realtek AC97 Audio
    Video : RADEON IGP 345M
    Driver Information
    Driver : ACPI
    Description : ACPI Driver for NT
    Driver : ACPIEC
    Description : ACPI Embedded Controller Driver
    Version : 5.1.2600.0 (xpclient.010817-1148)
    Driver : ALCXSENS
    Description : Sensaura WDM 3D Audio Driver
    Version : 5.10.00.3511
    Company : Sensaura Ltd
    Driver : ALCXWDM
    Description : Realtek AC'97 Audio Driver (WDM)
    Version : 5.10.5390
    Company : Realtek Semiconductor Corp.
    Driver : AliIde
    Description : ALi mini IDE Driver
    Version : 1.20
    Company : Acer Laboratories Inc.
    Driver : atapi
    Driver : ati2mtag
    Description : ATI Radeon Miniport Driver
    Version : 6.14.10.6404
    Company : ATI Technologies Inc.
    Driver : audstub
    Description : AudStub Driver
    Version : 5.1.2600.0 (XPClient.010817-1148)
    Driver : Cdfs
    Description : CD-ROM File System Driver
    Driver : Cdrom
    Description : SCSI CD-ROM Driver
    Driver : CmBatt
    Description : Control Method Battery Driver
    Driver : Compbatt
    Description : Composite Battery Driver
    Driver : Disk
    Description : PnP Disk Driver
    Driver : DMICall
    Description : Windows 2000 DMI Call Kernel Driver
    Version : 1.0.01.12050
    Company : Sony Corporation
    Driver : Fastfat
    Description : Fast FAT File System Driver
    Driver : FltMgr
    Description : Microsoft Filesystem Filter Manager
    Driver : Ftdisk
    Description : FT Disk Driver
    Driver : GEARAspiWDM
    Description : CDRom Class Filter Driver
    Version : 2.0.4.3
    Company : GEAR Software Inc.
    Driver : HSFHWALI
    Description : HSFHWALI WDM driver
    Version : 7.09.00
    Company : Conexant Systems, Inc.
    Driver : HSF_DP
    Description : HSF_DP driver
    Version : 7.09.00
    Driver : HTTP
    Description : HTTP Protocol Stack
    Version : 5.1.2600.2525 (xpsp_sp2_gdr.040919-1056)
    Driver : i8042prt
    Description : i8042 Port Driver
    Driver : Imapi
    Description : IMAPI Kernel Driver
    Driver : intelppm
    Description : Processor Device Driver
    Driver : IpNat
    Description : IP Network Address Translator
    Version : 5.1.2600.2524 (xpsp_sp2_gdr.040919-1056)
    Driver : IPSec
    Description : IPSec Driver
    Driver : isapnp
    Description : PNP ISA Bus Driver
    Driver : kmixer
    Description : Kernel Mode Audio Mixer
    Driver : mdmxsdk
    Description : Diagnostic Interface DRIVER
    Version : 1.0.2.002
    Company : Conexant
    Driver : Modem
    Description : Modem Device Driver
    Driver : MRxDAV
    Description : Windows NT WebDav Minirdr
    Driver : mssmbios
    Description : System Management BIOS Driver
    Driver : NdisTapi
    Description : NDIS 3.0 connection wrapper driver
    Driver : Ndisuio
    Description : NDIS User mode I/O Driver
    Driver : NdisWan
    Description : MS PPP Framing Driver (Strong Encryption)
    Driver : Npfs
    Description : NPFS Driver
    Driver : Ntfs
    Description : NT File System Driver
    Driver : ohci1394
    Description : 1394 OpenHCI Port Driver
    Driver : Parport
    Description : Parallel Port Driver
    Driver : PartMgr
    Description : Partition Manager
    Driver : ParVdm
    Description : VDM Parallel Driver
    Driver : PCI
    Description : NT Plug and Play PCI Enumerator
    Driver : Pcmcia
    Description : PCMCIA Bus Driver
    Driver : PSched
    Description : MS QoS Packet Scheduler
    Driver : Ptilink
    Description : Parallel Technologies DirectParallel IO Library
    Version : 1.10 (XPClient.010817-1148)
    Company : Parallel Technologies, Inc.
    Driver : PxHelp20
    Description : Px Engine Device Driver for Windows 2000/XP
    Version : 2.02.56a
    Company : Sonic Solutions
    Driver : Rasl2tp
    Description : RAS L2TP mini-port/call-manager driver
    Driver : RasPppoe
    Description : RAS PPPoE mini-port/call-manager driver
    Driver : Raspti
    Description : PTI DirectParallel(R) mini-port/call-manager driver
    Driver : Rdbss
    Description : Redirected Drive Buffering SubSystem Driver
    Version : 5.1.2600.2541 (xpsp_sp2_gdr.040919-1056)
    Driver : RDPCDD
    Description : RDP Miniport
    Driver : redbook
    Description : Redbook Audio Filter Driver
    Driver : Srv
    Description : Server driver
    Driver : swenum
    Description : Plug and Play Software Device Enumerator
    Version : 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Driver : SYMDNS
    Description : DNS Filter Driver
    Version : 5.5.1.6
    Company : Symantec Corporation
    Driver : SymEvent
    Description : Symantec Event Library
    Version : 11.6.2.4
    Driver : SYMFW
    Description : Firewall Filter Driver
    Version : 5.5.1.6
    Driver : SYMIDS
    Description : IDS Filter Driver
    Version : 5.5.1.6
    Driver : symlcbrd
    Description : Symantec Core Component
    Version : 1, 8, 54, 478
    Driver : SYMNDIS
    Description : NDIS Filter Driver
    Version : 5.5.1.6
    Driver : SYMREDRV
    Description : Redirector Filter Driver
    Version : 5.5.1.6
    Driver : SYMTDI
    Description : Network Dispatch Driver
    Version : 5.5.1.6
    Driver : SynTP
    Description : Synaptics Touchpad Driver
    Version : 7.8.9 20Nov03
    Company : Synaptics, Inc.
    Driver : sysaudio
    Description : System Audio WDM Filter
    Driver : Tcpip
    Description : TCP/IP Protocol Driver
    Version : 5.1.2600.2631 (xpsp_sp2_gdr.050313-1526)
    Driver : TermDD
    Description : Terminal Server Driver
    Driver : tifmsony
    Version : 1.0.1.3
    Driver : Update
    Description : Update Driver
    Driver : usbehci
    Driver : usbhub
    Description : Default Hub Driver for USB
    Driver : usbohci
    Description : OHCI USB Miniport Driver
    Driver : usbstor
    Description : USB Mass Storage Class Driver
    Driver : VolSnap
    Description : Volume Shadow Copy Driver
    Driver : Wanarp
    Description : MS Remote Access and Routing ARP Driver
    Driver : wdmaud
    Description : MMSYSTEM Wave/Midi API mapper
    Driver : msvcrt.dll
    Version : 7.0.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Driver : msvcirt.dll
    Driver : mfc42.dll
    Version : 6.02.4131.0
    Driver : msvcp60.dll
    Version : 6.02.3104.0
    Driver : msvcp70.dll
    Version : 7.00.9466.0
    Driver : msvcr70.dll
    Driver : ole32.dll
    Version : 5.1.2600.2595 (xpsp_sp2_gdr.041130-1729)
    Driver : olepro32.dll
    Driver : oledlg.dll
    Version : 1.0 (XPClient.010817-1148)
    Driver : advapi32.dll
    Driver : comctl32.dll
    Version : 5.82 (xpsp_sp2_rtm.040803-2158)
    Driver : setupapi.dll
    Lower Filters
    Driver : PxHelp20
    Version : 2.02.56a
    Upper Filters
    Version : 2.0.4.3
    Video Codecs
    Cinepak Codec by Radius : 1.10.0.11
    Intel 4|2|0 Video V2.50 : 5.1.2600.2180
    Intel Indeo(R) Video R3.2
    Intel IYUV codec : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Microsoft RLE : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Microsoft Video 1 : 5.1.2600.0 (xpclient.010817-1148)
    Microsoft YUV : 5.3.2600.2180 (xpsp_sp2_rtm.040803-2158)
    Toshiba YUV Codec : 5.1.2600.0 (XPClient.010817-1148)
    Microsoft H.263 Video Codec : 5.1.2600.2180
    Microsoft H.261 Video Codec : 5.1.2600.2180
    Intel Indeo® Video 4.5 : 4.51.16.03
    Indeo® video 5.10 : R.5.10.15.2.55
    Sony DV software CODEC
    DivX® 5.2.1 Codec : 5.2.1.1338
    Audio Codecs
    Microsoft IMA ADPCM CODEC : 4.00.0.0
    Microsoft ADPCM CODEC : 4.00.0.0
    Microsoft CCITT G.711 A-Law and u-Law CODEC : 4.00.0.0
    Microsoft GSM 6.10 Audio CODEC : 4.00.0.0
    DSP Group TrueSpeech(TM) Software CODEC : 1.00.0.0
    Microsoft G.723.1 CODEC : 1.02.0.1
    Windows Media Audio : 4.02.0.0
    Sipro Lab Telecom ACELP.net audio codec : 3.02.0.0
    Fraunhofer IIS MPEG Layer-3 Codec (advanced) : 1.09.1.49
    Indeo® audio software : 2.05.0.53
    Microsoft PCM Converter : 5.00.0.0
    ASPI Information
    System ASPI : ASPI is not installed
    Nero ASPI : ASPI is installed and working properly
    WNASPI32.DLL : 2.0.1.56 163910 bytes April 02, 2003
    Any help or suggestion would be great!
  24. I searched for the driver but the only one that can find is DVR-SK12D and not the one the I have DVR-K12D. I got it from:
    http://www.pioneerelectronics.com/pna/article/0,,2076_4273_128163990,00.html
  25. Can anyone please recommend me a program for burning data DVDs as well as DVD video, expect Nero? I seem to be finding ones that only burn DVD video.
  26. The next update is that I can't even burn image files anymore. When I try burning an image file with DVD Decryter, it stays for hours and hours on 0% and nothing happends. When I try to stop the burning process, the program does not respond, so I have to end the program through CTRL+ALT+DEL.
    Can anyone help please?
  27. Member
    May 2003
    You shouldn't need a driver as the drive should be detected correctly and an XP driver installed. The one for the SK12D won't be right as that is the same drive as yours but fitted in an external housing. It sounds to me like you either have a serious configuration problem or the drive itself is faulty. The only suggestions I can make are that you do either a complete re-install or a restore (presumably you have installation/restore disks that came with the laptop). If that doesn't work, it sounds like you have a faulty drive. As the laptop is a current model, I would think it is still under warranty. Contact Sony and get them to sort it out. You shouldn't have any problems with it being a US spec machine but you are in Europe (you don't say where) as the Sony warranty is worldwide.
  28. Member
    Mar 2008
    Canada
    I have a problem whenever i try to burn DVD's. My Nero software goes through 30% of the process (very slowly) then it suddenly stops and it used to say low virtual memory, later it started saying your VGA is not supported. SO i decided to install Roxio Media Manager 9 and with that before i even open the DVD buring software it scans my video card and it says error: VGA not recognized/not supported. What should i do???
