I downloaded a VCD and it works fine my sister's computer, but on my computer I don't get any sound. I can play other media formats like divx just fine, but I can't get any sound on VCDs. I've tried downloading various codecs and so far nothing has worked. I've tried different programs and all of them play the video, but none play the audio. Any ideas on what I should do??
Sounds (no pun) strange, as VCD is tightly defined, and if anything plays VCD at all, you should get audio too. What have you tried to use to play the VCD? I suggest PowerDVD to play VCD.
/Mats -
Yes, I tried playing them in Power DVD. As well as Media Player Classic, BSPlayer, and even VirtualDub. All give me video but no sound.
hmmm the standard vcd will be played any where dont need any codec... so weird may be u have some errors in ur operating system....
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum CapturingReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
