I used my digital camcorder and Adobe Premier to capture a VHS movie slideshow.
I now have a 5GB .avi that I need to capture about 100 photos from (jpeg or bmp), and I'm having a hard time figuring an easy way to do it.
Is there some way that I can just play the movie and capture the still frames as they go by?
Well if you can open the file in virtualdubmod, scroll to the frame you want, then open the video menu and click on "snap shot source frame"
you then have a choice of what format to save the still. couldn't be easier!!!! -
aaahhhh... but there is an easier way... I figured it out.
-Watch the movie in Premier
-Use the * button on the number keypad to mark frames
-When you have all your frames marked, you can export a movie as a bitmap sequence
-In the settings, only export the marked frames
Capture HDTV and Convert to approx. 350 MB avi file
By gapstar in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2010, 01:18 -
Interrupted WinDV Capture...Now I can't play the AVI file.
By ione in forum Capturing and VCRReplies: 11Last Post: 18th Oct 2009, 09:52 -
capture photos
By sunflower116 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 16:09 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 13:31 -
Can Windows Movie Maker capture photos while playing video?
By coody in forum Capturing and VCRReplies: 2Last Post: 5th Aug 2009, 22:09
