    Apr 2005
    California USA
    I have some MPEG video (480x480) that was extracted from my TiVo box. When I burn DVD's of it using SVCD2DVD it works great. However, I can't quite fit 2hrs on a DVD, so I edited out the commercials using Womble. Now I find that the DVD player won't let me fast-forward or rewind. Any ideas? Is there some way I can re-process the file so that FF and REW work? Thanks!
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is this the demo or the registered version?
    Apr 2005
    California USA
    SVCD2DVD is registered RC8, Womble is current demo version. Thx.
    Apr 2005
    California USA
    So I took the output from Womble and ran it through "GraphEdit" (the s/w I use to extract the MPG from the .tivo file) and now the movie will FF/REW, but the video has lots of weird artifacts. Sigh. This is all voodoo...
  5. Chrissy, I am also having the problem where I cannot FF or RW or move to the next chapter on RC8. If I try to, the DVD player (Sony NS715P) simply stops and goes back to the menu. I am recording using a Haupagge PVR350 with Haupaugge WinTV2000 software on XP. I am a registered user, and this was a clean install onto relatively clean XP (only installed Haupagge PVR, TMPEnc, antivirus, and anti spyware software). I had been using RC5 with the same haupagge software on this PC with a Win2K OS installation and had very good consistent results from SVCD2DVD. I record to MPEG2 480x480 at about 2300kpbs (max 2550 VBR), and use TMPGEnc to edit (Merge&Cut) the files to remove commercials etc.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. Can you drop me an email to test a version which should resolve this?
