http://www.nattress.com/free.htm
Can anyone get G Fifty Percent to work? I'm not seeing it under my list of filters anywhere...
Or, does anyone know of any other free slow motion plugins?
JES Deinterlacer can be used for 50% slo-mo, too:
The source material must be truly interlaced (i.e. 50/60 _genuine_ fields per second) so it can do a "bob" deinterlacing, i.e. make a whole frame from the half-frame (so you get 2x more unique frames to slow down). With slow shutter speeds this trick doesn't work because then the video is essentially progressive.
http://www.danslagle.com/mac/iMovie/tips_tricks/6016.shtml
I wonder if the Nattress Fifty Percent uses the same trick?
Are free avysinth and vdub filters so superior for restoration or not
By mammo1789 in forum RestorationReplies: 17Last Post: 7th Oct 2011, 15:53 -
Final Cut Pro Slow Export
By gooberguy in forum EditingReplies: 1Last Post: 5th Apr 2010, 17:23 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 12:32 -
Trouble W/ Video Filters Final Cut Express
By augiecrazy8 in forum MacReplies: 1Last Post: 2nd Sep 2008, 10:22 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 11:36
