I have been told by a few people that you can drop and drag using Win XP. However when I put a unformated CD RW in and try and drop and drag using explorer it says 'Drive is not accessible incorrect function'.
Am I doing something wrong?
is xp recognizing your drive as a cdrw drive, go to properties and check? Is it your only cdr drive, if not it must be the master device, xp only recognizes a cdrw if it is the first cdr it encounters.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 05:35 -
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 04:37 -
AVC H.264 MP4s displayed black by VirtualDub upon drag'n'drop
By bulgom in forum EditingReplies: 22Last Post: 6th Apr 2011, 20:18 -
Drag n Drop Problem
By Jim255 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2011, 03:26 -
Author tool that allows for drag-n-drop template authoring?
By jlietz in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 12:54
